  • 1 month later...
Coach T's voice. Man his accent freaks me out a little.. lol. Damn French Canadians. T-nation used to be so good for reading info... Now they just plug their products in just about everything.
Front squats are boss. I found my rowing strength increased once I included these, upper traps got a good stimulus too!
How are your numbers going Nick? I was just reading through the thread and a lot of the fella's in here have some good looking numbers. I'm assuming most of you train for PL comps?
The importance of leg day became most apparent to me during basketball lastnight.
Opposition were all gym brahs, at least 90-95kg a pop and mostly lean...I'm still my sleight/tall 77kg and NONE of these guys could move me out of the way in defense; they simply bounced off me and in offense I was able to hip push them out of the way to take boards. There's a reason a tree trunk is thicker to the ground...
All in the roots, brah
Edited by L33SH
  • 1 month later...
  • 2 months later...
Easy!
My squats are pretty average since I had 3 weeks off. I'm only 2.5kg off my pb but I've lost my endurance. I was doing 60kg x 13 now I'm doing 60kg x 5 and that's a struggle. Luckily I'm making pbs in bench and deads to make up for it lol
  On 28/08/2014 at 11:41 AM, jangles said:
New rep pb tonight, 175x5.
Fifth was a grinder.
Very strong squats mate what bodyweight you at?
I take it you are lifting for power not bodybuilding? Maybe not.. I rotate power sets and high rep sets. Firm believer in being strong as well as lifting to look good
I'm an easy 86kg@179cm, not lean, not big enough.
I've put on 10kg weight (probabaly 50% functional/muscle) and 50-60kg to my squat 1rm in last 12months.
Legs are where a lot of the muscle has gone. Stick legs, gone up 2-3 pant sizes.
I've always done a powerbuilding type split, I do Squats,Bench,Deads,Military as a strength exercise using powerlifting cycle templates., accessories are more hypertrophy.
Good stuff very solid at that weight. I have always found legs the hardest things to build but one of the most important. After many years of training its only the last 8 months that i have made ANY ground on them. I never used to squat which was half my problem but injuries from football prevented that. Now fixed my self up and squat 150 for 10 reps but i only go just before parallel. My bodybulding training has me doing slightly less weight with a lot more reps with long pauses at the bottom and this has made them grow. put on 2" in 8 months so happy with that.
My training partners legs are ridiculous and cant wear jeans or anything like that. I dont want to be the tailored pants dude hahah
With the 5x5 you will get 200 easy! good luck
I have a friend that is a tailored pants kind of guy.
I don't use 5x5, but I'll get there just the same!
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
