Whole team is done with 8's, so funny watching their expression, pure relief. Actually Max, Dan and Zoran do them Saturday, they have 180kg x 8 for 3 sets, no wraps
Jack did 195 x 8 x 3, Emad 170 x 8 x 3 and Spiros 160 x 8 x 3, last night.
Everyone starts wrapping from the first week of 5's next week. I know Max, Dan and Zoran have got 205 x 5 x 3 sets next week, then 220 x 5 x 3 sets the following week. They are on the 275kg squat plan.
Whats your first week of 5's Nick? Youre on the 220kg plan arent you? Must be 165 x 5 next week?
https://www.sau.com.au/forums/topic/422559-squattin/page/3/#findComment-6818813
I don't find the initial 3 sets so bad... it's the pause squats and high rep safety bar squats afterwards that kill me... just not used to that amount of volume... it hurts my vagina
180 x 8... fck that!
Zoran and Max look so comfortable squatting... all my reps are ugly grinds lol
yeah on the 220kg plan... but I want 230kg at nationals...
https://www.sau.com.au/forums/topic/422559-squattin/page/3/#findComment-6818855
I wasn't saying he IS evil... I was referring to his ownership of evilness...
you're not buying that are you?... oh well, at least I spelt it correctly this time hehehe
back on topic... why have you retired!? your partly to blame for getting me into this shit in the first place, now your quitting!
at least come watch Dan Green and eat pizza
https://www.sau.com.au/forums/topic/422559-squattin/page/3/#findComment-6819597
60kg x 10
70kg x 10
80kg x 10
90kg x 6
95kg x 3
Might add a 6th/1RM set to this so I can start using it to leverage my sets of reps and up their weight. 100 should be fairly doable for a start.
60kg x 10
70kg x 10
80kg x 10
90kg x 5
100kg x 2
The 100 was supposed to be a 1RM, but it felt easy on the way up, so I did another :D
https://www.sau.com.au/forums/topic/422559-squattin/page/3/#findComment-6821809
80kg x 10 means a fair bit more than 100kg for 1rm
Yeah but by the time I get to the 100, it doesn't lol
Prolly could have done 105 or 110 for the 1RM at the end. Though it's almost time to space out the working sets. Maybe shift the 70 to 75 and 80 to 90; 90 to 95 and 1RM to 105.
As long as the weight goes up everywhere :)
https://www.sau.com.au/forums/topic/422559-squattin/page/3/#findComment-6822062
if you are actually going to try and go for a single, then go
bar x 10
60 x 5
80 x 3
100 x 1
then either 105 or 110 depending on how you felt.
then keep going up by 5 or 10 depending on how you felt etc etc.
obviously do it in a rack with safety bars or spotters.
Whatever you fail on you'd be able to do the next week with less singles before it.
https://www.sau.com.au/forums/topic/422559-squattin/page/3/#findComment-6822228
60kg x 10
70kg x 10
80kg x 10
90kg x 5
100kg x 2
60kg x 10
75kg x 10
90kg x 8
100kg x 3
105kg x 1 (died on second rep; thank you safety bars)
I think the leg press is helping a fair bit with squat strength, along with progressively stepping up the weight on squats. I'm tryIng my best not to lose form as I step up the weight...it is still very ATG...however...I do "good morning" the weight up when I am struggling in the hole sometimes. Is this a bad thing? Indicative that I should be further back on my heels?
https://www.sau.com.au/forums/topic/422559-squattin/page/3/#findComment-6825705
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
