Have you tried stretching or using a really light weight at the end of your sets to try and push lower? I've always had good hip flexibility despite my long legs. My hamstrings are pretty poor though.
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6842246
Next session go
bar x 10
40 x 8
60 x 5
80 x 3
100 x 1
then go 115 and 120
stop doing a million reps before your 1rms
Why you gotta hate on my gazillion reps? I love the volume stuff.
I know that's the best thing to do to increase 1RM, i.e. cut down on my volume...so I'll probably turn to it when I start plateauing bad with the current setup. But for now I enjoy sticking the 1RM after a heap of working sets. Because Birds
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6842252
Argh
http://answers.yahoo.com/question/index?qid=20100122075103AABalxd
Came across that when tryin to find that bad technique thing where the ass "rolls" or "dips" during a squat. What's it called again?
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6842501
Cheers
Yeah I gave up reading after the first two comments. The chosen answer supposedly a trainer for an international weightlifting association? Err...
There's misinformation and then there's MISSINGinformation!
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6842620
do your volume after you go heavy, not before... just do enough to warm up, hit a pb, then do a heap of volume work
^^ This.
You're not going to find your 1rm doing it your way.
You're only going to find your exhausted 1rm.
Do it like I said, then once you fail a 1rm, have a 5 minute rest, then load up your volume sets and go for broke back mountain
  • Like 1
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6842960
60kg x 10
75kg x 10
90kg x 8
100kg x 3
110kg x 1
Got a bit worried on the 90, being down a rep from Friday. Felt good about the 100 x 3 though, so I shot for 110kg and there it is. Will try and get 2 of them next time or shoot for 115.
60kg x 10
75kg x 10
90kg x 8
100kg x 3 (died half way up on 4th rep)
115kg x 0 (died half way up)
Didn't make the 115 tonight; back just didn't want to work with me after the fail on the 100s. Next time maybe!
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6846202
  • 1 month later...
60kg x 10
75kg x 10
90kg x 8
60kg x 10
80kg x 10
100kg x 4 (fail on 5th rep)
110kg x 0
90kg x 3
Was sick with a cold this week, debating whether to come. No one ever got anywhere by being home with a cold, so here I am.
Feel like I'm leaning forward too far on the heavier weights and the motion is turning into a bit of a good morning, as my back is giving way before my legs are. Seems to be consequential of trying to squat all the way to my ankles in oly stance; need to sit back on my heels more and keep the hips from coming up before my back. Hoping to post better results next sesh.
https://www.sau.com.au/forums/topic/422559-squattin/page/6/#findComment-6898825
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
