60kg x 10
80kg x 10
100kg x 4 (fail on 5th rep)
110kg x 0
90kg x 3
Second cold lol, can the environment gimme a f**kin break?! Better form this time around...
60kg x 10
80kg x 10
90kg x 7
100kg x 4
105kg x 1
https://www.sau.com.au/forums/topic/422559-squattin/page/7/#findComment-6907230
60kg x 10
80kg x 10
90kg x 7
100kg x 4
105kg x 1
60kg x 10
80kg x 10
90kg x 7
105kg x 2
110kg x 0 (failed half way up)
https://www.sau.com.au/forums/topic/422559-squattin/page/7/#findComment-6911668
That's no true; by your standards of a squat I was doing 10 of them before I switched to ATG...big difference. I squat to get bigger legs and ATGs in heavy volume have been doing that for me; it's been great. I also made the 110 a few weeks back.
https://www.sau.com.au/forums/topic/422559-squattin/page/7/#findComment-6912160
Birds, you make out that your the only lifter that squats deep, do you honestly believe that?
Now in regards to squatting to get bigger legs............singles most sessions, really?
Anyway, its very clear your happy with your training and weights, and that should be every lifters goal, so power to you mate, keep going.
https://www.sau.com.au/forums/topic/422559-squattin/page/7/#findComment-6912380
No I don't believe that. Plenty squat as deep as me and with loads more weight. I'm still a squat beginner as far as I'm concerned. I just don't think parallel and ATG weights should be compared with each other (outside of competition), when range of motion makes a huge difference to the weight you can squat. Considering that my legs are significantly bigger now (still not huge) than when I was squatting parallel with much more weight, there has to be truth to that.
I will come down for a visit with Charlie soon, only because I'm open minded enough to see and try things from a different perspective. But I can't promise that I'm going to swap out my ways for what you present me. You have to understand that I don't reject your methods or project my own onto anyone who doesn't ask me for them...I just like stepping outside the norm and trying my own things. If no one ever did that, we would never find alternatives; we would never advance beyond the norm. I don't mind being a guinea pig for that, even if it's at the sacrifice of my own conquests (though I don't believe it to be).
https://www.sau.com.au/forums/topic/422559-squattin/page/7/#findComment-6912441
so halfway up means up past parallel right?
How will squatting to below parallel but not till your calves touch hamstrings allow you to lift more?
you're not failing at the bottom.. you are failing half way up which would be back up past parallel.
or are you assuming that a legal depth PL squat is a 1/4 squat?
https://www.sau.com.au/forums/topic/422559-squattin/page/7/#findComment-6912521
Look at how knees and muscles work...the lower you go to the ground, the more resistance you have to put up with and it's non-linear. It also alters the dynamic of back position. There's a reason you could do more pullups if you didn't have to clear the bar with your chin each time.
Half way up = expression. Read into the semantics however you want, Trollga, it doesn't mean a literal 50% of the ROM. I don't think I got past parallel.
https://www.sau.com.au/forums/topic/422559-squattin/page/7/#findComment-6912549
Hey guys my gf leg workout atm is
Leg press 100kgs 3 x 10
Calf raises 100 kgs 3 x 10
squats 20 kgs 5 x 5
Lunges 10 kgs 3 x 10.
Hip raises? 10kgs 3 x 10
Training once a week
Her legs are toned as is but wants them to look bigger and more musclier in a feminim way though but is stuck atm and not much gains. Some pt's have said try doing 20 reps and others 8. What are your recomendations?
https://www.sau.com.au/forums/topic/422559-squattin/page/7/#findComment-6912578
lol @ feminine way. Muscle doesn't grow feminine or masculine, it just grows...with food and training. It does happen overnight though, so tell her to be careful and check the mirror regularly in case of sudden muscle growth into masculinity. Those IFBB bodybuilders have to be real careful they don't accidentally get too big when they are putting on muscle too.
Tell her to squat before leg press, for starters. And start upping that weight...20kg is a newbie warmup. My 55 year old mother squatted 20kg for 10 reps last week...first squat she's ever done in her life.
If you always do what you've always done then you'll always get what you've always got.
Shit, I'm starting to sound like Markos :/
- condescending but true advice...check
- use example of relative or client...check
- old expression/adage...check
https://www.sau.com.au/forums/topic/422559-squattin/page/7/#findComment-6912603
    • Uhhh if anyone sees this - I bought a BRZ years ago, on my fulls soon so back on the market for the R34!
    • Research research research, and tackle the important things first, like the rust, because as a wise old hippie and some crazy horses once said "rust never sleeps" Nothing good comes easy and fast, and nothing that comes easy and fast is typically good
    • I made an extension of the item circled above in red that is hard wired to the battery and tucks away nicely in the engine bay, could easily do the same if it in the boot, just run the extended cable out under the bonnet or boot lid, I then just stick the charger on a milk crate to get it off the ground
    • It's purpose will be to stop the regulator plug from leaking oil. As GTS said, if it seals properly, it will mainly just have the effect of slightly higher oil pressure. I'll assume tolerances/fitment in the relief valve aren't that close that the washer being missing won't let it vent at 100% capacity too.
    • I put the charger in the engine bay and run the power cord down through one of the holes in the undertray, or at the back end of the engine bay, any time I need a car to be on a charger outside. In fact, I bring the extension cord up through into the engine bay so that it's not dragging around where it could get wet, or easily unplugged.
