Selling my 17 inch Tommy Kaira 3 piece signature rims I believe they are from the R33 Tommy Kaira special, be great rims for someone that has a Tommy Kaira or wants to buildd a replica (sorry I only have the rims, some parts can be ordered from Tommy Kaira eg some of the badges). They looked good on stock R34 GTT but not wide enough for the body kit and customization I have done. Second hand value they are worth 10k plus. They have good tyres and only need slight touch up (or colour code to your car/liking for a custom look). I have them sitting in my garage as spare wheels and tyres (hence not actually used anymore) I'm willing to consider reasonable offers & may even accept other rims as part payment (subject to suitabilty for my car and me liking them). Negotiable on shipping.
Cheers Dylan 0432983298 [email protected]
    • Nope. The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head. To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy. I had to manually (and delicately) clean the gunk out of my speedo.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
