  • Replies 41
Yep, I've got them. Bought them from some speciality wiper web site in the UK. Worth every cent. Think I got both fronts for about $40 delivered from the UK, when similar blades were $50-60 EACH in Australia.
Pretty sure this was the place: http://www.wiperblades.co.uk/
No part number, I measured the stock blades and bought matching sized ones. I think one was a Mini and one was a Citroen something...
I spent ages trying to work it out. Realised rather than looking for other Nissan's they matched up to, it was easier to use the tape measure. End result is perfect, just wished I'd done the rear at the same time.
I didn't think about the rear.. hmm
ok Josh's comment got me interested, so I dug through my email and found the invoice.
Bosch AR18U - 9.24 pounds
Bosch AR21U - 10.15 pounds
8.10 pounds delivery, 27.49 total, so about $40 at today's conversion rate.
The 8.10 works out to $11.82 AUD delivery. To me, thats about what I'd pay locally for delivery, so no big deal.
I needed wipers for my daily, thought I'd try out these aero type blades. Being $11 delivered I wasn't expecting much, however these are the best wipers I have ever used.
So ordered a set for the 33 :)
http://www.ebay.com.au/itm/300817661727?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
http://www.ebay.com.au/itm/300817661915?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_2527wt_1271
Gees you make it all sound so complex- just go to Super cheap - (off memory one is 550mm and the other is 600mm) and switch them over, they just pop on off. Takes 3 mintues each side. The twin blade ones wipe away the same amount of water as the top end ones dont they...
Super cheap wanted $50 each, online theyre $40 delivered for a pair...
I might try those. Good tip, thanks.
The links you had for those blades are for another model of car though right? Not a Stagea?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
