Does anyone have the material specifications on the skyline/silvia rear cast steel knuckle?
The reason I ask is that last weekend I broke a rear knuckle at the track, throuch the lower balljoint mount up to the wheel bearing. The crack is obiously due to fatigue and there are several outher craks in the same area.
What I want to do is weld reinforcement gussets up from the bottom edge of the lower baljoint block up towards the lower brake caliper mount and from the rear of the lower balljoint mount to the shock mount, to reduce the stress concentration around the failure.
Obviosly this upright is a bin job, but I want to reenforce the the new knuckels, as apparently this a common problem with the skyline/ silvia rear end, and I dont want this happening again.
The car is enginered and road registerd, but welding to a upright is a big no go zone if the material specification is unknown, and id prefer not to have to get spectro analasis done as its not cheap.
I wouldn't say that's a common problem with a Nissan rear end at all.
I've never seen that particular breakage before. I've seen cracked & broken subframes (we are repairing one at the moment in an S15) and broken arms but never an upright like that.
I guess that failure is directly related to one or more big hits. I have never seen one break like that either.
The most common failure I've seen other than bent arms is the inner mount for the arm ripping off (upper or lower), they are probably worth reinforcing.
I have had 1 customers drift car with this failure.
and have have had a r33 road car with a cracked upright in this position which we found before total failure, this car had a large wheel to kerb impact tho
And have a couple of mates who have seen this happen over at Ebisu
I have never hit a kerb with the car, or any real impact, have had it on the car for 4 years. Only major load i can think of which would cause that would be jumping turn 1 apex at mallala have done that many times.
yeah i previously had a crack starting on the rear LCA mount on the cradle, fixed that one decently tho before it propergated.
Very very common breakage, have seen at least 10 and know of heaps more.
Best solution is driftworks rear knuckles.
You could reinforce it, same process as welding front knuckles
Yeah only problem driftworks you lose the drum handbrake. Checked my other side just out of interest and cracks have already started at same place so yeah definately is a fatigue issue over sustained hard track use, thats what im doing now reinforceing like my modded front knuckles.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
