Wrecking R33 Gtst Manual
SERIES 1 PARTS
I have a couple of rb25det motors and a complete manual conversion for anyone that is interested
All my aftermarket parts are listed separately
r33 gtst rear 5 stud conversion
hubs
rotors
calipers etc
$220
R33 complete boot trim
$70
r33 gtst front hubs,slotted vented rotors and brakes good for 5 stud
$220
r33 gtst drive shafts
great condition
$30ea
Rear reo
$40
r33 rear cradle just the cradle
$20
Radiator support great condition
$50
r33 gtst brake master complete non abs
great condition
$30
r33 engine crossmember perfect for rb conversions
$50
R33 power steer rack
Great condition
$30
r33 front sway bar
$20
R33 series 1 engine loom
Good condition
$150
R33 series 1 ecu
$70
R33 gtst gearbox $1150
r33 series 1 behind the dash aircon stuff
make a offer
r33 series 1 window trims from door and car the one that always fade
make a offer
r33 overflow bottle
$10
R33 gtst ignition barrel and locks with key
Good condition
$130
R33 gtst side mirrors
$20 each
R33 s1 drivers window switch
Good condition
$70
r33 passenger side gaurd with blinker
maroon and white
$20
R33 drivers side Gaurd with blinker
White
$20
R33 series 1 bonnet
White and gunmetal grey
$120
Series 1 front reo
$60
R33 headlight passenger s1
Chrome backing
Broken mounts still works tho
$60
R33 headlight drivers s1
Black backing
Broken mount still wrk fine
$60
R33 s1.5 front bar
White could do with coat of paint
$130
R33 series 1 dash
$30
R33 series 1 a
Manual diff 4.11
$140
R33 gtst centre console
Good condition
$20
R33 series 1 radiator
$50
R33 doors bare
good condition
$20 each
R33 gtst tail lights
Great condition
$20 each
R33 glovebox
$20
R33 boot with aftermarket wing/spoiler looks similiar to standard one lights up skyline
$20
R33 boot with Gtr copy wing
White
$100
R33 handbrake with full handbrake cable to hubs
$30
R33 passenger window reg motor
$35
R33 drivers window reg and motor
$40
R33 passenger window switch
$20
R33 bonnet latch and cable
$30
R33 bonnet latch bracket
$20
r33 boot and fuel flap latch assembly
$20
r33 air con unit/display
$20
R33 rear bar maroon, silver and white
$30
R33 complete air con set up with everything!
condenser
compressor
dryer
lines etc
$130
R33 rear seats
$30
SERIES 2 PARTS
R33 series 2 dash complete in good condition
$80
R33 series 2 manual diff
$140
R33 genuine gtr grill
White bit rough needs to be fixed up
$40
R33 series 2 headlight
One broken clip for grill
$70
Bare rear subframe
$20
rb25det series 2 afm pink label great upgrade for rb26 I have 2
$60 or $80 for both
R33 manual cluster series 2
$70
hubs
rotors
calipers etc
$220
r33 gtst front hubs, rotors and calipers
$220
r33 series 2 gtst drive shafts
great condition
$35
r33 gtst series 2 brake master complete abs
great condition
$50
R33 gtst gearbox
$1150
R33 clutch master cylinder
$60
$50
R33 series 2 power steer rack
Great condition
$30
R33 aftermarket front strut brace
$40
r33 front sway bar
$20
r33 series 2 behind the dash aircon stuff
make a offer
r33 series 2 window trims from door and car the one that always fade
make a 0ffer
r33 overflow bottle
$15
R33 washer bottle
$30
R33 standard shocks and springs
$40
r33 gtst series 2 front seats
Great condition drivers have minor tear
$50
r33 series 2 rear bar silver
$40
R33 gtst series 2 ignition barrel and locks with key
Good condition
$130
R33 gtst series 2 side mirror passenger silver
$30
Silver
$30
R33 gtst series 2 centre console
Good condition
$20
R33 series 2 door passenger
good condition
$20
Great condition
$30 each
R33 glovebox
$20
$50
R33 pasenger window reg motor
$35
R33 drivers side window reg and motor
$40
$20
$50
$40
$30
r33 series 2 air con unit/display
$30
R33 series 2 steering wheel with air bag
Make a offer
R33 series 2 complete air con set up with everything!
$150
i have all the interior plastics etc
So much more just can't think text me or pm me if you need anything
Gold Coast can post
0487924497
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
