Thanks for the great shots Chris.
I noticed your Bayside Blue GTR only ran the first courses then was noticeably missing. Looks like either camber wear or the tyres chunked out cause there's lots of tread on them otherwise. Bugger! Well, come out for the next Texi and give it a go again. Your car looked really good out there.
I dont think the BMW had enough body roll :P If my 33 is a boat then that surely was a cruise ship :P but was good to see the variety. It had some serious tires on it to.
Make a note next texi there will be a matte black 32 gtst with a purple cage ripping skids ;) CANT WAIT!
Thanks for great photos Chris, got some really nice photos of my car on there! :worship:
As with all Texi's, i'm not pictured. ;op
only 1 set posted so far, I'm sure some others would have got ya. how about the video i took on your camera?
a big thanks to everyone who organised this event and helped out, had a great day as usual.
now to sort out my power steering issues!!!
Also keep an eye out for pic's at https://www.facebook.com/ScottSterlingPhotography
enjoy :)
I'm going to upload all the vids today!
I just get sadface when there aren't any full-res pics of my car... but as you say, "yet".
Steve, in about an hour my first video will be up and you'll be happy I think.
Will post the link as soon as vimeo does it's thing. Love'n this new camera!
Geoff drew my attention to the slo-mo vid. 24 seconds in, thanks! =-D
yet?
what car were you driving?
#36, and you're probably right... just not "yet".
Part of me wants me to bring my camera and tripod and do photos all day, but the more selfish part of me wants to do skids all day and not worry about my equipment. ;o)
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
