Hi all,
I have a 2002 model Subaru Impreza WRX for sale in WRC blue color.
The car runs beautifully and has never given me any sort of grief. This car does not choke on start up or do anything a WRX shouldn't do. It starts up quickly, first time every time.
Before I bought this car, I checked out maybe another 6 or 7 WRX's of the same model on the market at the time and this one was by far the cleanest and best running, and I have kept it that way.
I already got the RWC done this month on the 14th which is valid for 30 days, so it is still useable until the 14th of April.
The Good:
- 11 months rego
- RWC
- WRC blue color
- Brant immobilizer from factory, requires a 4-digit pin to start up, not good news for thieves
- STi sideskirts
- slimline number plates
- 3" exhaust and Apex'i panel filter, gives the car that WRX rumble everyone loves
- headunit with AUX in, and comes with an amp
- brand new tyres all around
- still have original owners manual from Subaru
- 180xxx on the clock which is very reasonable for a 10yr old car
- no oil/fluid leaks
- never been in a crash, never been stolen, no finance owing, clean title
Message me anytime on 0425 531 332 if you have any questions or want to inspect the car. I guarantee the first person who inspects and drives the car will buy it
Located in Tarneit, Melbourne's west
Thanks
*PRICE DROP* $10,999
*will trade for an s15, must have rego and rwc, must be manual, and have cash my way
post-55161-0-97223200-1364629624_thumb.jpeg post-55161-0-11565400-1364629633_thumb.jpeg post-55161-0-10272400-1364629646_thumb.jpeg post-55161-0-95801200-1364629652_thumb.jpeg post-55161-0-77129400-1364629663_thumb.jpeg post-55161-0-49227800-1364629673_thumb.jpeg post-55161-0-69199400-1364629688_thumb.jpeg post-55161-0-78806500-1364629697_thumb.jpeg post-55161-0-67105800-1364629704_thumb.jpeg post-55161-0-55277400-1364629711_thumb.jpeg
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
