Hello people
After an unsuccessful meeting with a member of our coat-of-arm near Melbourne airport, I will be needing a complete set of front panels etc for my V35.
Do we have a reliable supplier in OZ for the needed parts and who are they?
Any useful help here would be appreciated.
Cheers
Craig
https://www.sau.com.au/forums/topic/422621-replacement-panels/
  • 3 weeks later...
As an update, the local smash repairer has it all in hand and looking at a 4 week turnaround. They have sourced all parts and repairs are under way.
Makes it easy
Handover inspection will be slow tho - want to make sure it is right
Makes it easy
And they would have hit up Nissan local for it. I have a mate of mine the does V35 bits by the container load.
Good to see it is sorted. 4 or 5 figure sum?
  • 4 weeks later...
Hey Chris
RACV has pissed us around for a week and only after I phoned on Friday (twice) did we get any action on them giving authority for the new light. Problem is now they are going straight Nissan with the hope that will make it somewhat more expedient than your estimate.
I pointed out that we could have done this 6 weeks ago and saved not only time off the road but also some stupid stuffing around with second-hand lamps.
Not happy Jan. And they know it!
They are going to hit the same wall I did. Nissan have to make them. They have. Minimum order request and I say that has been met but it is still 25th before production finishes for these orders.
Up to you in the end but that is nissan Japan saying that , not me.
Well, the world turns and time marches onward.
Seems Nissan Japan has done its bit and the headlights are made and we should land it Sydney on Thurs, hopefully here Friday or Monday.
Not holding my breath though. Been here too many times.
I should have given this another crack.. Usually when they tell me a date they are not far off it. Looks like someone placed a decent order for lights within the last two weeks.
Car is finally painted and awaiting the aforementioned headlight.
Pity that in these many weeks, they failed to notice the huge creases and dips in the roof turret. When I pointed that out to them, they were very surprised indeed.
The Painless Dent Removal guy was there and had a look saying that something heavy had been placed on the roof to cause that damage, not just a bump.
And my photos bear him out too.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
    • Look, realistically, those are some fairly chunky connectors and wires so it is a reasonably fair bet that that loom was involved in the redirection of the fuel pump and/or ECU/ignition power for the immobiliser. It's also fair to be that the new immobiliser is essentially the same thing as the old one, and so it probably needs the same stuff done to make it do what it has to do. Given that you are talking about a car that no-one else here is familiar with (I mean your exact car) and an alarm that I've never heard of before and so probably not many others are familiar with, and that some wire monkey has been messing with it out of our sight, it seems reasonable that the wire monkey should be fixing this.
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
