Well woke up the went to get the car of the trailer and f*ker won't start
So did the usual checks and the fuel pump is not working
Blew the fuse so replaced it and blew it again so I pulled the f**ker out.
dodgy 101' the workshop that installed it f**ked it up and the pump has shorted out on the locating housing
The pump has been flapping around and knocking agains the housing and shorting out on certain bends... So now that its fixed up and the pickup fixed hopefully I have fixed the surge issues
sooo
some updates on this old girl
car is going to jez for the following
install surge and twin pumps
will throw the haltech in and have a tune for e85
hopefully it will result in more reliability up around teh 300rwkw mark(and some less lag)
also have a harness bar to throw in and a new rpm harness
then once tuned will put the ikea shit in and get another wheel alignment and book her in for a wakfield day
yea baby
also bought a leak down teaster so i can keep track of how the engine is feeling as it slowely dies in a fire
Did you stage the fuel pumps?
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
