give us the info son!
+1
Custom diffusers and under trays interest me...
Looks good
Custom?? Or off the shelf??
Sitting down ladies you have three options
1: dry carbon front lip and dry carbon undertray $1500
2: dry carbon front lip and Frp under tray $1200
3: Frp lip and under tray $900
Parts coming together for the new engine
Cheers to god12a on fronting up the good( Tarmac solutions)
No I can plan my super mega hyper excellent catch can system
Dash ten on pasengers side
Two dash 12 on the drivers side, angles and spaced so as not to hit shit and be able to tighten the f**ker up
Baffled and shit
[url=http://s236.photobucket.com/user/fatzgtsr/media/pete%20gtr/s2%20r33%20gtr/image_zps52ed1d07.jpg.html]image_zps52ed1d07.jpg[/url
Plan is to run a electric oil pump below the air filters that's triggered by the haltech when over 6k rpm and a set boost level, this will suck from the nismo catch can to the passengers side dash ten
Then a dash 12 vent to the oil cap
And a dash 12 drain from the second oil tank
Are they gate hinges?
Stainless door hinges I thought lol
sooo you ladies dont like my flaps?
lol
super jealous of catch can system (stupid East-west engine), I read back a few pages and cant find detailed info on what the setup will be
lucky for you i knowcked up this awesome diagram
i do belive it will answer all questions
on the potential awesomness of my proposed system
catch can.pdf
attachicon.gifcatch can.pdf
Thanks. As complicated as an oil cooler setup with filter relocation kit lol
Will look into getting an electric oil pump for mine too
Yea hook me up
You shorted your issues?
I've got fittings welded to the sump, I'm just going to let the oil drain back and do its own thing *fingers crossed.
Turbowerx pump cost me just under $500 delivered, flick me a PM with an offer I can't refuse :) It comes with -6 AN in and out fittings but you can get others if they are too small/big.
http://www.ebay.com.au/itm/151158789695
Edited by SimonR32
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
