Put some hawk pads in they seem very good
Should be for 500+ ... What the f*k?
Suspension seems good on the street
Will give a run down tomorrow at the track
Just going out to replace the o44 now and then pack her up for track time tomorrow
Come in spinner
  • Like 1
What compound pads? I started with blues for the track and have just stepped up to HT-10's. Like them a lot but probably could have gone to the HT-60's.
They are way cheaper out of the US just $60 shipping that's a pain.
Yea I got the 60's
Anyway bitter sweet today
Got out and did one lap and the lift pump started to die, starve the engine putted around for a few more laps but the miss just it worse
Turns out the previouse noise was the external pump starving so I replaced that for no reason, so the spare will now go in as the lift pump
In other news the coil overs were epic
Knocked 2 seconds of the pb in one lap and I am sure there would have been another few without much trouble
Highly recommended... Turns out those mexicans at race pace know what they r doing
so ripped the intank pump out
had rust on the 044 housing
also fine rust on the intank sock (e85 is cleaning out the fuel system obviously as the tank is plastc)
replaced it and the car ran well but still had a missfire
will replace the fuel filters and see if that fixes it tonight
if that doesnt work ill compression test the old girl to see if i have hurt her running those laps at the track while down on fuel pressure
next tune a fuel pressure sensor is going in and will add engine protection to haltech
Yea they are pretty dam good on the street soak up the bumps well
At he track when you cut a kerb it just squats and down to business
Old coil were like getting punched in the face when you hit a kerb and then u were thrown across the track
If only someone would tell us what the pharken spring rates are.
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
