Well done mate.
Awesome run!
cheers
Epic!!!
tops funeveryone should get out there and have a crack.. you cant wipe the smile off ya face
What width and offset plus tyre are you running again?
18x10.5+ 15
Sick run..
Have you thought about changing the diff ratio to the r32 gtr's 4.11?
runs 4:11
i considered 4:4's but having been to phillip island the car hist 7k in 5th there so no need to go shorter
eh? R33 GTRs have the same diff ratios as R32 GTRs bud
what he said
This is a good event and Fatz does not leave anything in the bag when he has a go.
The new brakes were amazing and the new tyres really had some grip as reflected in the improvement in times.
This idea of running at night with headlights is something new and provides a challenge when picking braking points and apexes.
  • Like 1
Whilst slinging shitt at MR MAN boobs is very cool with some of his crazy offs,,,please explain this little mis-adverture of yours mate. If you wanted to play in the mud and grass,,,you could have borrowed his 4 ring circus or my patrol.
  • Like 2
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
    • Unless my sensor just died, was only a couple months old, I strongly believe it didn't. How can I test it? I never mentioned it being 20:1+?
