did you check out your engine mounts?
thats a fair chunk of twist to just pop the input shaft, maybe even the bearing went in the box and put too much heat through the shaft.... hehe shaft
Wouldnt the engine and box (lol box) move as one?
so have been doing some investigation into my catch can setup following eastern creek happy fun times
on long left hander’s i noticed that oil pressure would drop to 30psi under high load
i can confirm this with the Haltech data logger, plus warning lights and i was going so slow i have time to check guages mid corner at 180km/h
This has only cropped up since going to the hancock rubber ( never had a issue on the r888 which are slower)
so i checked my oil levels as i do and she was at the hump in the dipstick so 10 litres of oil in the slightly larger stock sump
so slapped another 2L in which brought the oil level up to crank level and about 1 inch above the kink in the dipstick (about 3 inches higher than the full line)
next session this resulted in perfect oil pressure on left handers however the downside was the catch can pumping about 1 litre of oil out the drain and under the car
i already had a cunning plan to fix this and was expected considering the thrashing teh car cops/ engine wear
i will be going to version 3 catch can which involves putting it the one way valve to the catch can and activating the external pump that i had installed (have not been using it till required)
i am hoping this will give me a extra year or two of thrashing ( or about 10 gearboxes time) before i have to start backing off the revs to control blowby
will also extend the -20 drain hose to back behind the rear cradle to that the poor bastard behind me cops it and not the under part of my car
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
