did you check out your engine mounts?
thats a fair chunk of twist to just pop the input shaft, maybe even the bearing went in the box and put too much heat through the shaft.... hehe shaft
Wouldnt the engine and box (lol box) move as one?
so have been doing some investigation into my catch can setup following eastern creek happy fun times
on long left hander’s i noticed that oil pressure would drop to 30psi under high load
i can confirm this with the Haltech data logger, plus warning lights and i was going so slow i have time to check guages mid corner at 180km/h
This has only cropped up since going to the hancock rubber ( never had a issue on the r888 which are slower)
so i checked my oil levels as i do and she was at the hump in the dipstick so 10 litres of oil in the slightly larger stock sump
so slapped another 2L in which brought the oil level up to crank level and about 1 inch above the kink in the dipstick (about 3 inches higher than the full line)
next session this resulted in perfect oil pressure on left handers however the downside was the catch can pumping about 1 litre of oil out the drain and under the car
i already had a cunning plan to fix this and was expected considering the thrashing teh car cops/ engine wear
i will be going to version 3 catch can which involves putting it the one way valve to the catch can and activating the external pump that i had installed (have not been using it till required)
i am hoping this will give me a extra year or two of thrashing ( or about 10 gearboxes time) before i have to start backing off the revs to control blowby
will also extend the -20 drain hose to back behind the rear cradle to that the poor bastard behind me cops it and not the under part of my car
    • Yeah 4wd (boosted) has a recess in the firewall for the booster, and 2wd is flat - the example in the link shows the flat surface. When you deleted the booster, did you just attach the factory slave cylinder directly to the recess in the firewall with no adaption?
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
