Take two laps to warm the brakes up ( it's very rear grabby during those two laps)
Then it become epic under brakes
Shows the limitations of the stock master
I have a massive list of things to do as usual
Number one is install the ap twin master balance bar setup I have for it with rear adjuster
It's got 4 degrees up front and 3 at the rear
Tyres seem to like that geometry
IKEA arms makes it easy
Why some much at the rear fatz? Appears to understeer in the correct GTr manner then get snappy when you touch the throttle. Less neg on the rear be a better set up?
yea was just trying a few things the car was previously at 3 front and 1.9 rear
the plan was with a agressive front lsd i wanted abit more snap at the rear at the start of the corner to suit my driving style...the 4wd then kicks in and we get out of the bend hard blazing all 4.
sau day ill dial it back as jenna is driving as she is not a massive fan of a snappy rear end.
however once the 4wd is back and working 100% then ill give it another bash.
4 degrees at the front was getting epic turn in though.
Yeah all the cool kids run four or more degrees at the front. Reckon the Japanese use massive spring rates because they don't run so much neg camber.
Looks funky but then it is next to impossible getting the right offset rims.
Edited by djr81
Get an Evo, they do that from stock. Properly driven should be faster into/through most corners if lacking some of the straight line snot.
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
