No wonder the GTR is now going so fast - you have Nigel Mansell driving it for you.
It looks like with the new roll cage there is not enough room for Fatz.
What are your thoughts on the cage - it seems as though they are made to a price? I asked them for a quote for a cage the same as Neil's and they have not replied with a price.
for a bolt in cage its is very good and i would recomend their work
i would ask them for a weld in next time purely because it gives you more space
i only have a bolt in as the car is registered and it can be removed if i ever get pinged
my main problem is the seat sits too high as its on rails and slides because jenna drives the car
i am going to cut and shut it to drop it about 2 inches which will be better
problem is if i do that the car is realy becoming a race car.... so in hindsight i should have paid for the weld in cage and made it a propoer race car with rally rego ( which you can do now)
Can you get Rally rego on circuit cars?
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
    • I have seen enough fire and brimstone from TSBs about roloc disks causing spun bearings that foreign object contamination is top of mind for me. For sufficiently large particles you might be right but usually it’s a distribution of debris and some of the larger particles can also break down and shed bits. If local shops report RTV contamination in a turbo is enough to wreck them I’m taking zero chances if I can help it.
    • Ask and ye shall receive! (eventually... ☺️) https://www.goo-net.com/usedcar_shop/0170208/detail.html
    • Weird ! Same Same with mine. Autoexcel in Bonnyrig is your friend !
