Put some hawk pads in they seem very good
Should be for 500+ ... What the f*k?
Suspension seems good on the street
Will give a run down tomorrow at the track
Just going out to replace the o44 now and then pack her up for track time tomorrow
Come in spinner
  • Like 1
What compound pads? I started with blues for the track and have just stepped up to HT-10's. Like them a lot but probably could have gone to the HT-60's.
They are way cheaper out of the US just $60 shipping that's a pain.
Yea I got the 60's
Anyway bitter sweet today
Got out and did one lap and the lift pump started to die, starve the engine putted around for a few more laps but the miss just it worse
Turns out the previouse noise was the external pump starving so I replaced that for no reason, so the spare will now go in as the lift pump
In other news the coil overs were epic
Knocked 2 seconds of the pb in one lap and I am sure there would have been another few without much trouble
Highly recommended... Turns out those mexicans at race pace know what they r doing
so ripped the intank pump out
had rust on the 044 housing
also fine rust on the intank sock (e85 is cleaning out the fuel system obviously as the tank is plastc)
replaced it and the car ran well but still had a missfire
will replace the fuel filters and see if that fixes it tonight
if that doesnt work ill compression test the old girl to see if i have hurt her running those laps at the track while down on fuel pressure
next tune a fuel pressure sensor is going in and will add engine protection to haltech
Yea they are pretty dam good on the street soak up the bumps well
At he track when you cut a kerb it just squats and down to business
Old coil were like getting punched in the face when you hit a kerb and then u were thrown across the track
If only someone would tell us what the pharken spring rates are.
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
