Yeh, when I first went for a ride in a car with RPM modified Teins I went out the next week and bought some and sent them off to RPM. They are damn good things and suspect its all in the valving more than the spring rates.
Had to grab a second pair when I went GTR rear cradle and got the chance to do another set...largely the reason why my thing even as a rwd car cant blazed 2nd gear with 330rwkws...just traction and hooks up!
What sized rim are you running? Thought of throwing some Carrera Cup slicks at it?
yea they sell themselves these shocks
awesome!
run a 10.5 inch rim
i have thought about the slicks but have been too lazy to put some on
Come to my joint
Bring six pack
And you can have a look while I drink beer
Will do. How far is your place from WA?
Struggling to understand why the F/R rate differential. Should hook up with that soft a rear spring. Just worried youd never get on the gas because of the front rate?
Why the rear is a lot softer than the front? You need the car to squat to get the power down.
No you dont. Not in a GTR on the track. Maybe for drags and maybe for rally style stuff where you cant carry all the corner speed that is available but not for the track. The thing that kills you is understeer, not lack of traction. A large F/R spring rate differential makes the car push.
ill ever get a alignment for the next track day and maybe adjusted slightly to take into account my 140kg girth
You've slimmed down?
New filters in still missing
Compression test showed 160,158, 150, 138, 135, 160
Ill try some new plugs and coils just to make sure then it's off to dvsjez to have the fuel pressure checked and protection added to the haltech
Might be time for the new motor
So this pos is now booked in to Jez to get some new engine love on the 18th
So hopefully it will be back with additional compression
New engine has som e cool shit
big sump
front lsd
hks 2530
port match manifolds
hks dump pipes
some cams
cam gears
nizmo plenum
Hks ic
Ill also get the egt sensors installed and some fuel pressure protection
Then book it into a few track days
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
