new ps lines in
just need a belt and some ps fluid
then to jez to have a new surge tank made ( i think the low quality alloy of the tank made by profab= corrosion on the inside= blocked injectors?) the only thing i have not replaced
article on cheap alloy and corosion
http://news.motorsport.org.nz/e85-and-fuel-cell-compatibility/
f**k you brad
Thats an interesting read mr fatz. As you found your fuel on the day to be A ok then this seems like a very possible cause. As we know doesnt take much to block up the filters on injector baskets.
I can't see why the surge tank would be a problem. You may not be happy with Brad but that doesn't make his aluminium corrode. Plus I've been running one of his tanks about 12mths longer than you without any issues, there are plenty of them out there.
I think you need to look somewhere else. Feel free to point and laugh if I'm wrong
Have you got a fuel cooler Pete ?
It's looking to me that E85 does not like getting hot and when it does it starts to lean out the engine :(
As for the filings, could it be simple a case of he didn't flush the tank or lines ( if using braid that is ) out properly ?
I had a lot of fuel temp issues due to dodgy injectors and kept getting major lean outs, mine was actually due to an O ring swelling in my injectors after changing everything else... The fuel cooler does a pretty good job now and on track it keeps the pumps pretty quiet, however it was only fitted as the fuel temp was an issue due to something causing it, not just due to track use.
The amount of times i had my injectors out was silly, turns out they were the wrong ones! They look near identical side by side too.
Sorry if I was a bit vague this mourning Pete, I was struggling to hear you, the cover on my 6+ is crap :(
Thats interesting Mat, can you explain the o ring issue a bit more
I'm in the same boat as Pete I think, the longer I was out their the more it played up
1st session car ran fine, end of second session ( 1st passenger ) it was starting to break down the 3rd session I got like 5 laps then I had to come 4 session I got 4 laps, 5th session ( the one I did a 1.04.6 in ) I couldn't even do a full hot lap
I drove on to that session and the fuel was already 42deg when I came back it was just on 70 :(
I think my issue is fuel heat soak but I am very curious to know what the O ring issue you had was and how it effected the fuel for something else for me and Pete to look in to :thumbsup:
Probably unrelated to your issues, mine was completely the wrong injector, not rated for E85 causing the O rings to swell... They were some POS 1400cc things!
Oh, lol, ok cool then, I have ID1300s so I should be sweet there
I have the XSPURT 2000's and they havent missed a beat since they have been in :)
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
