Hi I need some help I Have a r32 GTST with a Mines Ecu in it and I was finding it hard to start When cold I would have to pump the Peddle. Once Started the car Ran fine and felt good to drive with out the Rev limit etc and I have a Air/Fuel meter which read Rich on boost. I then got a Stock Ecu and just swapped them around to See if the car would Start with a Stock one and it did but still ruff. and the car was running on Stoich and lost the rev limiter etc. So then I put the Mines Ecu back in and it still runs but i have Lost the Rev limit and it doesn't run on Rich on boost (14psi ) is still on Stoich so now its like it De tuned ?? Is there anything i can do to get it back to Normal back to the Rich and Rev limiter on? I have tried Disconnecting the battery and removed it again and installed it but still the same .... any help would be great Cheers Claude
it's more likely that the o2 sensor wire was bumped when you changed the ecu and that's causing the different reading from the air fuel gauge (given that the stock ecu should read richer than a tuned ecu). those things are useless anyway. they read off the stock o2 sensor which is a narrow band. your car can actually be leaning out and they can still read rich, because they are designed to work between 14:1 and 15:1 air/fuel ratio, which is lean (it's fine for cruising along, but very lean for hard acceleration). 12:1 is the ideal AFR for full throttle, and up will into the 13's is lean, but will still read as rich on the air fuel gauge.
also, an ecu shouldn't lose it's settings just from unplugging it.
there is also the possibility that the o2 sensor is simply dead. with the stock ecu in, and most likely with the mines as well, the afr should fluctuate between rich and lean at idle and when cruising along with light throttle.
as for the running rough, try letting the fuel pump prime before starting the car (turn the ignition to "on" for a few seconds before turning it all the way to "start"). if the fuel pump is aftermarket then it may need to prime before it will have enough fuel in the system to run properly. but then that will only affect it for a few seconds after starting. if it is rough all the time, then it could be coil packs, spark plugs, ignitor module, afm, or one of many other things causing the issue.
and if the car still had no rev limit on the stock ecu then there is something else going on. the stock limit should be about 7500 to 8500 rpm (depending on the accuracy of the tacho, i've seen them be over 500rpm out at redline compared to a pfc handset reading).
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
