Very tidy car, well done!
Quick question with the seats, I've searched lots but can't find a answer - will the airbags work if you replace the front seats? I've always thought they had a sensor in the stock seats to activate the airbags in a crash?
Thanks Chris
By airbags do you mean the one in the steering wheel? There was only one wire to connect and that was for the seat belt
Didn't know there was an airbag sensor for the seats
Thanks Chris
I thought I read somewhere that they have a pressure sensor in the front seat for airbag deployment? Maybe it goes by the seatbelt sensor?
dem wheels man :woot: its to bad my wallet didnt let me get a set -.- great choice, though i think doing yours in gunmetal with a black lip would look better then a full gloss black just an idea :P
how long did it take to get your seats fromt japan mate.. I've been looking around for pair for a while now..
(p.s looks like my wheels wont be here till next week so I'll send you a photo then)
  • 3 weeks later...
  • 4 weeks later...
So this happened tonight. At my mechanics house hanging out and waiting for a service on the car. Had to drop someone off, on my way back down Merrylands Rd I've hit a pot hole
The way the car felt and what I could hear I thought it was the coilover but after checking it out it's was the camber arm.
  • 1 month later...
A few early birthday presents for myself on tuesday. New coil packs as mine were starting to fail and also a new clutch
Coil packs are in, clutch will go in in a few weeks or when I blow the current one. I was trying to blow it on wednesday at the creek but that didn't happen lol
    • This isn't for lotsa powers, and time and effort isn't even a thing I'm concerned about The whole reason is "Just because fun", and "Just because fun" is what I do And whilst there are other kits, with better and more modern turbos (Rev9 use the same Kraken manifold I believe), where in Sydney can I do a drive in drive out with the after sales support that MX5 Mania give My Turbo 86 made around 200kwatw on a AVO turbo kit, and was over 100kg heavier than the MX5, but it was a blast to drive around the streets, until I crashed it.....DOOH, so somewhere around 200 ish level and some whooshy noises and I'll be happy driving to work, the shops, or heading into the country with Jackie for Devonshire tea So, thanks Dose for your info, it sounds like a 0.64 will be fine for what I'm after👍 The only real racing I do nowadays is to the toilet
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
