Thanks Raj. Can't remember off the top of my head at the moment. I recently bought a daily so we decided to go a little heavier to handle any future upgrades.
I've hit a problem...... my turbo decided to die on me friday morning on the way home from work
First time I've driven the car in a week after going to the creek. Drove the car to work thursday night, no problems. On the way home, roughly 10mins from my house , went to shift in to third, no boost, no power and I could hear a whistling/whining noise
So I eventually got home, let the car cool down, came back out 15mins later and kicked it over
https://www.facebook.com/photo.php?v=10154262357330717
Engine switched off
https://www.facebook.com/photo.php?v=10154262395460717
So I had it towed to my mechanics friday night and the plan is to pull the turbo out and send it to GCG and have them open it up and see whats wrong
Hopefully it won't cost an arm and a leg to rebuild it
While the turbo is away we'll throw the clutch in, do a service, timing belt and maybe upgrade the oil pump while we are in there.
Mat and Tim blow gearboxes, I blow turbos :P
  • Like 1
So I'm in 2 minds at the moment as to what to do with the car
1. Rebuild the GTRS. Reasoning behind this is to attend the 32GTR 25th anniversary day/cruise and the SAU trackday later this year. Also put the new clutch in while the turbo is getting rebuilt so I can run it in.
Once these 2 events are over, take the 34 off the road
2. Pull the 34 off the road now, rip the motor out and start the build. Haltech PS2000 ECU, cams, cam gears, upgrade the oil pump, injectors, 6boost, HTA3076r + a few other things
I'm more leaning with option 1 as I'm hanging for these 2 events and there's no way I'll have the motor finished by mid August.
Bloody cars, always break at the worst times
  • 3 weeks later...
Nice car mate, see it heaps around my area :) I recognise the plates
Get rid of the HKS filter, they don't seal properly, I had them on my 32 when I first got it and had dust in the I take tract :(
That sux what happened to the turbo, have you got a quote yet from GCG to repair it ?
Have a look at the Kando TD05H-18or20G as a cheap quick replacement if GCG want to much
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
    • Car looks clean as. You ended up getting quite a bit done 😂  So what's the plan for the exhaust?
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
