  • 7 months later...
Wow it's been a while since I've updated this thread
Let's see.... the car has been off the road for the last 6-7 months while I save and stock pile parts.
I've been driving an auto civic around..... yes a civic, please don't think bad of me :worship:
:P
So, now for the parts.
RB26 cam covers, also picked up the cam gear backing plate and a pair of -10 breathers
Oil catch can/washer bottle combo
  • Like 1
Its about time some updates got made! Haha.
Thats a Hi Octance can setup yeah? Very nice mate.
Also, pics of civic :P
Yeh HiOctane catch can
No pics of the civic, it's bad enough that I own it, don't want people to know what it looks like :P
The cam covers were sent to be painted earlier in the week, just waiting on the baffles for them
The car is due on the hoist hopefully monday. Drop the gearbox and pull out the old sump and install the new one.
Install everything else then work out what fittings I need and measure up lines
So keen to start the work.
After months of saving and stocking up parts it's time to get started
When I got to my mates places early yesterday morning and walked in to the garage to see this I was jumping around like a school girl. :D
I was finally able to get my hands dirty with this car
We dropped the gearbox, removed the clutch and flywheel and removed the old sump.
Couldn't belive what we had to take off to get to 2 small screws at the rear of the sump.
Also noticed that my passanger side engine mount is completely screwed so both mounts will be changed, Nismo mounts of course :P
We hit a bit of a snag late yesterday afternoon. After removing the timing belt, harmonic balancer then the oil pump, we found that the new billet gears I've got are to big for this pump.
It looks like they are for an N1 oil pump. So my mate was going today to get it swapped for the correct gears as well as pick up the new engine mounts.
So that's it so far. I'm back at work for the next 3 nights so I won't be able to get stuck in to the work until saturday afternoon/night but with my mate being on holidays, he'll be able to pump out a fair bit until them.
  • Like 1
Got a problem with the intake manifold though. On the stock runners it sits to far to the left and the throttle body hits the fuse box.
Not sure if there is a difference between the 33 and 34 manifold but something does seem right with this.
I'm going to have to head to plazmaman on monday before work
There is a different between 33 & 34 manifold - one of them is the the Idle Air valve. But if yours fit on the manifold then it means you've got the right one.
I was told you dont need to relocate anything to install these. Keen to see what the issue turns out to be.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
