  • 1 month later...
So..... I still haven't got the car back yet. It's been a bit of a saga.
Since the last update I dropped the ECU off a Haltech, a few days after that I receive a phone call to go pick it up, the ECU was fine.
After a couple more weeks of troubleshooting between Tyler and my mechanic, trying different parts (in case mine were having problems) they found a possible wiring issue.
The car went back on a tow truck and headed to an auto elec at Rouse Hill.
They pull the harness out and find a couple of problems, 3 shorts in the wiring actually, including the fuel pump running 2 power sources.... no idea why
After they were fixed up, Tyler heads out there to see if he can tune it. One of the problems we were facing before was that it was over fueling, no matter how low the injectors were turned down, it was still dumping fuel.
Back on the tow truck she goes but this time back to my mates so we could go through the car again.
We had a suspicion that we may have hooked up the fuel lines wrong. After a quick phone call, it was confirmed that we had the return line out of the fuel rail that goes in to the FPR incorrect.
Instead of having it coming out of the middle of the rail, we had it at the end. So we switched this over and she started and ran a lot better, not 100% but better.
I won't get in to details but after a few conversations, the decision was made to send the car elsewhere.
So since tuesday last week, the car has been at JEM
Adam, being the genius he is, found the cause of the over fueling issue (on top of the fuel return issue)
The way it was explained to me was that the spacers that were supplied with the fuel rail, that are used for the bolts that attach it to the motor are too long.
That, along with the caps that go on the end of the injectors, are affecting the way the fuel is delivered.
Apparently he has come across this before on an identical setup.
The car is also getting a wideband o2 sensor installed while it's there.
I got a little teaser pic from Adam on one of the R34 owners FB pages of my car on the dyno the other day
Even though the car is getting looked after and even with the rush and running around, it won't be making the SAU/RTDC track day this weekend..... :unhappy:
I'm gutted as this is the second track day I've been booked for and missed but hey, I'll be making up for it once she's back on the road.
So hopefully I should be getting a call sometime next week to go and pick her up.
  • Like 2
Wow what an episode. I hope you haven't lost a mate through all of this but I'm glad to hear the car is in good hands and that it will be finished soon.
On a random note I found my old iPhone a few weeks ago and I've been using it just as an iPod because its still got all my music on there and I randomly decided to go through the photos and I found photos of the cruise up to the northern beaches where I met you and raj for the first time. Got a few pics of your cars on there haha
  • 2 years later...
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
