Hi all,
This is a EOI, am thinking of not going power FC but microtech instead.
Power FC boost controller kit is brand new in box.
Looking at $400 or a direct swap for equivalent such as HKS, turbosmart eboost 2 etc.
I'd be after something brand new in box if I am to trade.
PM me or text to 0421 289 174
Edited by chilzzi
https://www.sau.com.au/forums/topic/422684-power-fc-boost-controller-kit/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
