Hey got some left over bits n pieces laying around i want to get rid of.
(R34 gtt bits from 3/2000 series 2 model with 105000k's)
1.Complete stock exhaust system ($100)
2.Stock side mount intercooler with air duct ($100)
3.Airbox with snorkel ($80)
4.Volts/oil temp/boost gauge cluster ($30)
5.Stock (auto) ecu ($50)
6.Stock injectors ($100)
7.Stock coil packs ($50)
8.Stock turbo wastegate actuator ($20)
9.Standard height springs ($40)
10.Stock airflow meter ($50)
11.Stock 0p6 turbo with rb20 actuator (10psi) has some shaft play was working and boosting fine when removed ($400)
12.Aftermarket (low) kingsprings will fit R33/r34 ($150)
(R32 gtr bits from 7/92)
1.climate control unit missing fascia ($15)
2.Twinturbo pipes ($40)
3.Stock ecu ($80)
4.Stock 440cc injectors no leaks when removed at 95000K's ($200)
post-74489-0-63939300-1364785698_thumb.jpgpost-74489-0-49557900-1364786084_thumb.jpgpost-74489-0-60827000-1364786101_thumb.jpgpost-74489-0-01237900-1364786109_thumb.jpgpost-74489-0-24444600-1364786120_thumb.jpgpost-74489-0-52516500-1364786172_thumb.jpgpost-74489-0-58035500-1364786185_thumb.jpgpost-74489-0-03377600-1364786194_thumb.jpgpost-74489-0-62529400-1364786202_thumb.jpgpost-74489-0-77865800-1364786220_thumb.jpgpost-74489-0-59266200-1364786232_thumb.jpgpost-74489-0-09878500-1364786254_thumb.jpgpost-74489-0-69955800-1364786239_thumb.jpgpost-74489-0-55070600-1364786261_thumb.jpgpost-74489-0-69471400-1364786269_thumb.jpgpost-74489-0-18323900-1364786275_thumb.jpgpost-74489-0-28353300-1364786281_thumb.jpgpost-74489-0-97842400-1364786287_thumb.jpg
how many Ks have the king springs done and do you have the model/part number of them? Just want to make sure they're low and not the standard or super low ones. Also location please? Would consider grabbing stock air box + Springs from you but if not in sydney will need shipping.
Airbox and Snorkel (sold)
Standard wastegate (sold)
R32 Gtr Ecu (sold)
R34 Gtt king springs (sold)
All prices on remaining parts negotiable want this stuff gone. :thumbsup:
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
