So your saying (160 rwkw) "ONLY" which equates to 208kw at the engine, which is what everyone uses...car dealerships etc... a brand new showroom falcon xr6 has what 210kw???? except its 2013 technologoy, not half 86 half 96.....over 20 year old parts..... "ONLY"
Ok it is a good amount but it is not in any way remarkable look at the hp per cc it is fairly average considering you can buy a r1 tune it and make near 200hp.
Also the e36 BMW's can make 300hp with a few mods the xr6 falcon is pretty much the same engine from the xf's just with 4 valves per cylinder. What is the hp per cc or ci of a xr6 compared to some older cars there are some that do near the same.
Edited by pf.
Yer it's just like an xf, you know apart from having an over head cam, wait make that two cams not one, oh and 4 valves per cylinder.... Yer..... It's identical :dry:
Already got one bro but the build on that will be epic when I can afford it. The 25/30 will be turbo and forecasts are in the region of 30k for that build the 30/25 will be cheap as possible porting and chamber work will be the big cost.
even at trade prices, etc, you will be spending many thousands to get anywhere near 160kw at the wheels. as i think i said in an earlier post, a mate of mine built a rb30 from the ground up in his r31 and it only made just over 230hp. this thing had a lot of work done. major head work, cams, crank was modified to flow more oil, twin throttle bodies, big injectors, etc, and it reved to 8 or 9k. from what i gather, it may have been the fastest non turbo rb30 in australia (ran a high 13). his old man was an engine builder and had been using rb30s in his speedway cars from the 90's, and was the first person i knew with an imported skyline (had a turbo 31 back in the early to mid 90's).
so to try and similar power with 500cc less is going to be hard work, and the car will drive like an absolute dog (i know my mates did).
as for comparing new engines to old engines, you can't really. they were built in different eras with different regulations and objectives. newer engines run closer to the limit to begin with as this helps them with emissions, and there isn't much in the way of technology advances that can be used to get bigger gains.
but as i also said earlier, i'm happy to be proven wrong about the power you make, but i have a pretty good idea of how poor the reliability is going to be getting anywhere near that power. i know how often my mate had to rebuild his car (but it did have a hard life. was primarily used for drag and burnout comps, but was still registered)
Im probably at 10k and im hoping to make over 160kw atw...wouldnt know yet till its tuned, alot of time and money is spent to do this sort of project. but back on topic...i dont understand what your trying to ask? you want help with putting an rb30 head on an rb25 block....if no one has done it (which no one commented has) then how do you sugest we can "help"..... if hasnt been done there probably is a reason...but by all means do it so when your budget built is better than the 10K plus wasted you can laugh in my face :)
pf its good that you are thinking outside the box mate but for the$$$ that you are spending you are not going to get much bang for your buck~dont take this as being negative
take it as being realistic
I'd hope that anyone doing up an N/A RB motor would be aware of the costs involved, OP I'd say that head design is going to be absolutely critical for your goals (that and a lot of compression).
I recall seeing a triple carb RB30 HR31 from R31House on youtube a while ago, sounded cool too, could always try pissing off the pesky fuel injection? FWIW, 202's are regarded as a lump of a motor as well.
For the money, I'd be putting an LS in it, because you'll probably be spending a similar amount :D
Ok a bit of an update head was checked by me and was bent it can be straightened. The straightening will increase compression greatly but he 25 block will drop it greatly so I have some numbers to play with :) So far the head is going to cost me about 2500 I plan on spending 2k on the computer and ignition so to come under the 10k mark it leaves me with 5k for block and fuel system. Costs will blow out so I have to play it safe with my money.
The head price is service,porting,machining and a cam.
so you are spending 10k on an NA 30 Head with 25 block?
This is quite possibly the worst idea I have ever read on a car forum. For 10k do something decent .... even though I hate the idea you can get an Ls1 crate engine for around 6k
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
