So your saying (160 rwkw) "ONLY" which equates to 208kw at the engine, which is what everyone uses...car dealerships etc... a brand new showroom falcon xr6 has what 210kw???? except its 2013 technologoy, not half 86 half 96.....over 20 year old parts..... "ONLY"
Ok it is a good amount but it is not in any way remarkable look at the hp per cc it is fairly average considering you can buy a r1 tune it and make near 200hp.
Also the e36 BMW's can make 300hp with a few mods the xr6 falcon is pretty much the same engine from the xf's just with 4 valves per cylinder. What is the hp per cc or ci of a xr6 compared to some older cars there are some that do near the same.
Edited by pf.
Yer it's just like an xf, you know apart from having an over head cam, wait make that two cams not one, oh and 4 valves per cylinder.... Yer..... It's identical :dry:
Already got one bro but the build on that will be epic when I can afford it. The 25/30 will be turbo and forecasts are in the region of 30k for that build the 30/25 will be cheap as possible porting and chamber work will be the big cost.
even at trade prices, etc, you will be spending many thousands to get anywhere near 160kw at the wheels. as i think i said in an earlier post, a mate of mine built a rb30 from the ground up in his r31 and it only made just over 230hp. this thing had a lot of work done. major head work, cams, crank was modified to flow more oil, twin throttle bodies, big injectors, etc, and it reved to 8 or 9k. from what i gather, it may have been the fastest non turbo rb30 in australia (ran a high 13). his old man was an engine builder and had been using rb30s in his speedway cars from the 90's, and was the first person i knew with an imported skyline (had a turbo 31 back in the early to mid 90's).
so to try and similar power with 500cc less is going to be hard work, and the car will drive like an absolute dog (i know my mates did).
as for comparing new engines to old engines, you can't really. they were built in different eras with different regulations and objectives. newer engines run closer to the limit to begin with as this helps them with emissions, and there isn't much in the way of technology advances that can be used to get bigger gains.
but as i also said earlier, i'm happy to be proven wrong about the power you make, but i have a pretty good idea of how poor the reliability is going to be getting anywhere near that power. i know how often my mate had to rebuild his car (but it did have a hard life. was primarily used for drag and burnout comps, but was still registered)
Im probably at 10k and im hoping to make over 160kw atw...wouldnt know yet till its tuned, alot of time and money is spent to do this sort of project. but back on topic...i dont understand what your trying to ask? you want help with putting an rb30 head on an rb25 block....if no one has done it (which no one commented has) then how do you sugest we can "help"..... if hasnt been done there probably is a reason...but by all means do it so when your budget built is better than the 10K plus wasted you can laugh in my face :)
pf its good that you are thinking outside the box mate but for the$$$ that you are spending you are not going to get much bang for your buck~dont take this as being negative
take it as being realistic
I'd hope that anyone doing up an N/A RB motor would be aware of the costs involved, OP I'd say that head design is going to be absolutely critical for your goals (that and a lot of compression).
I recall seeing a triple carb RB30 HR31 from R31House on youtube a while ago, sounded cool too, could always try pissing off the pesky fuel injection? FWIW, 202's are regarded as a lump of a motor as well.
For the money, I'd be putting an LS in it, because you'll probably be spending a similar amount :D
Ok a bit of an update head was checked by me and was bent it can be straightened. The straightening will increase compression greatly but he 25 block will drop it greatly so I have some numbers to play with :) So far the head is going to cost me about 2500 I plan on spending 2k on the computer and ignition so to come under the 10k mark it leaves me with 5k for block and fuel system. Costs will blow out so I have to play it safe with my money.
The head price is service,porting,machining and a cam.
so you are spending 10k on an NA 30 Head with 25 block?
This is quite possibly the worst idea I have ever read on a car forum. For 10k do something decent .... even though I hate the idea you can get an Ls1 crate engine for around 6k
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
