Couple more spare bits and peices I wanna get rid of, located Sydney.
GREDDY INFORMETER TOUCH -
Practically still new, only used for about 5months. Was on a R33 s2 (stock ecu), literally plug and play, plugs into consult port under driver side dash and gets it power source there as well. Found it an extremely useful tool to monitor engine activities, only removed due to upgrading to haltech ecu which was not compatible. $450ONO (Will ship Free Aus wide)
link to part for more info and some pics:
http://greddy.com/pr...formeter-TOUCH/
post-40593-0-73566600-1364802683_thumb.jpg post-40593-0-79029900-1364802719_thumb.jpg
R34 GTT / R33 S2 PINK LABEL AIR FLOW METER -
Bought off another forum member from here, was apparently off an R34 GTT that was being wrecked wit ~70,000kms on the clock, I've put on ~6000kms before upgrading to a Z32, was in perfect wokring condition, only removed due to upgrade. $80
Another pink label air flow meter I bought as a spare off a wrecker for $150, still looks in neat prestine condition, only problem is....while I was undoing with million layers of bubble wrap it came in, I became impatient and started tearing it apart accidentally snapping off a piece of the mounting side lols, good thing is, broke off in one INTACT peice and still fits back on like a piece of jigsaw puzzle, seems like a bit of super glue would do the trick ;)....going cheap (SEE PICS) - $45
post-40593-0-52142200-1364803656_thumb.jpg post-40593-0-61332400-1364803681_thumb.jpg
Thanks guys.
    • Well it does have a motor with the same DNA as an Accord V6 motor. The J30A is a successor to the Tiger rice cooker C32A motor found in those cars.
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
    • When going to a suspension shop should I send them the default nissan settings or just let them do their own thing? I ask this because I have aftermarket rear camber arms and my car is lowered a bit (front end is basically stock after I change to those nismo bushes)
    • Ok sounds good, thanks for your help. Hopefully if I end up changing it to the nismo bushes I don't get that veering issue. I don't think there's a point in lubing up these bushes again. Weird that it it makes just as much noise with all the grease inside it versus without grease prior to removal. Bizarre.
    • Yeah, you don't need camber bushes on stock arms to make a car drive straight unless it's got another problem. F'rigsample, slide the thing into a kerb, bend the front subframe mounts a little....subframe is now twisted, shifted or otherwise in the wrong spot...and you need to do funky stuff with the wheel alignment to get it to drive straight. Maybe a little more caster on one side, or a little more camber. FWIW, I can have my camber off side to side by a half a degree or more, and either way, so more one side, or more on the other, and the car doesn't really want to pull to one side. It will definitely ride road camber differently, and want to track uphill (ie, towards the centreline when on the LHS of a normal crowned piece of road, like it should) or want to roll downhill (which it really shouldn't). But on fairly flat road surfaces, like the middle of a 3 or 4 lane motorway, a half a degree either way doesn't make a lot of difference. I sometimes do quite a few miles with my wheel alignment messed up, because I don't always get a chance to set it right again after a serious dismantling, before I have to drive it to work again. Like, a whole week's worth of daily shuffle.
