  • Replies 49
you could use fibreglass to fill the boot to a point, then put a few mm of bog on, to fill the rest of it, bog is fairly light, but 20mm of it will make the boot quite heavy
Speak to someone like spoilershop?
or, you can buy my boot off me, with the 2 boot pods and GT wing, I wanna swap back to a GTR wing...
