lol thanks guys!! oh and did someone say a bimmer thread?
that last one was a little tricky to take with right hand: camera trigger, left hand: lens focus ring, left knee: on the steering wheel, right foot: accelerator flooring it.
[edit]
but hey since this is a forum for skylines, the closest i could get to a nissan was this:
546960_300370893404678_411941788_n.jpgScreenShot2013-04-18at110031PM_zps00354d
okay now the weekend's here, i need to get some car photography done in perth so i can stick to the rules of this thread. must. find. skylines!
Edited by aaiezz
Jesus, 1/8000th shutter speed. Lol. Don't think i've ever taken a shot at 1/8000th.
Should of stopped down a bit aperture wise?
yeah that was a test shot anyway to see the distance of the Z drifting around the 300, i changed it all around after that to get a better pan shot with a slower shutter speed and a smaller aperture. it was fun though, instead of a step ladder i had to stand up on the roof of my grand cherokee and get the angles right. good kids the car owners, went along with everything i asked!
  • Like 1
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
