2 challenges in one month.
Challenge the first..
Body weight on the bar, squat till you can squat no more.
high bar, low bar, whatever..
each squat must break parallel (which means your hip crease when you bend, must be below the top of your knee at the bottom of each rep)
if you want to go Ass to Grass then go for it.
Challenge the next
Body weight x 1.5 on the bar, everything else the same.
Video from side so people can see depth.
Don't hurt yourself
Don't dodge this challenge.. at least do one of them.
If you can't squat your own bodyweight on your shoulders... STOP EVERYTHING!!!!
Put down your iPhone
Put down your designer microfibre towel
Walk over to the squat racks and squat the bar many time.
Add 5kg each side. place bar on upper back and squat many times
Continue doing this until you need to lie down for a while.
then lie down
then get up
then do 4 more sets.
Pick up your iPhone, micro fibre towel, your bottles of pre and intra workout drinks, full up your post work out drink bottle and drink it.
get home and eat many many animals and stuff animals eat.
go back in 2 days time and do it again.
repeat for 3 months.
https://www.sau.com.au/forums/topic/422759-squats-the-challenge/
  • Replies 82
  On 02/04/2013 at 1:37 AM, Trozzle said:
challenge for the ladies? I don't know many girls who can squat their own body weight for reps
Really? I thought you trained at Elite Physique in Canberra. I saw 15 do it there at the last comp, only a handful were PL'ers, most were Crossfitters or physique competitors, a few went 2 x bw
Canberra has some very strong girls
might give this ago.
dont expect i'll get many reps out compared to others here but hey we will see. Weighed in at 67kg so I'll attempt at 70kg cause i'm a big kent like that.
not sure how to upload the video either
Birds - stay up top to breath out and in, then down.... towards the end you might need to stay up top a little longer to take 3 or 4 breaths so do it if you want.
Do what you think is right instead of looking for ways to cheat.. lol
I'd say your hands/shoulders and lower back will be fried before your legs give up anyway so resting in standing position to wards the end will be hard anyway.
FIGJAM - upload vid to youtube
link it here.
Nah mate I train at Anytime Fitness haha, commercial gym in all its glory!
I'm more speaking for the girls on here.
Thanks for thinking of us Troy, but I won't be doing this one.
  • 4 weeks later...
    • THERE IS NO IAT SENSOR ON ANY SINGLE TURBO RB. And the one on an RB26 is not for "engine control" - it's really too big and too slow and is only used for over-temp alarming (as far as I can tell). Anyway, you don't have one. You want/need one for the Link, then you need to buy one, find a spot for it, and wire it in. You do know that the stock boost solenoid is not capable of "control", right? It is merely on or off, for the low boost (5 psi) and high boost (7psi), which the ECU enforces mostly based on gear. The stock solenoid is not for PWM control and is not plumbed up in a way to provide it. If you want to control boost properly, then you need a proper MAC valve. And yes, you can wire either of them direct to the ECU. Well, I assume you can - I don't know what the boost solenoid pins on the plug and play Link are capable of. They really should be as capable as any normal Link - but seeing as it is plg and play, it might be limited to stock functionality. Read the doco.   You really do just want to plug stuff together without understanding how it works, right? I can't help you there. I don't know the plug types or pinning on half the stuff you're asking about. If I had to do it I would sit down with the wiring diagrams, the car/looms and a multimeter and work out what is what.
    • Light should be a pressure switch, not a sensor.
    • The pressure light likely has a different sender to a pressure gauge, its been too long for me to remember for sure. Just have a look for another sender down near the oil filter. If you are confident in your rewired pressure sender reading correctly, you can be pretty sure it is just the dash light's sender failing, it is a pretty common thing.
    • It would be nice to see the result, but instagram is a click too far
    • That is a series 1 front end (grill, bumper, headlights). I'm not sure if you are trying to confirm if your whole car is series 1 or just the headlights, but the build date and vin# on the plaque in the engine bay would be the best reference for what it was when it left the factory (noting a lot may have changed over the years)
