2 challenges in one month.
Challenge the first..
Body weight on the bar, squat till you can squat no more.
high bar, low bar, whatever..
each squat must break parallel (which means your hip crease when you bend, must be below the top of your knee at the bottom of each rep)
if you want to go Ass to Grass then go for it.
Challenge the next
Body weight x 1.5 on the bar, everything else the same.
Video from side so people can see depth.
Don't hurt yourself
Don't dodge this challenge.. at least do one of them.
If you can't squat your own bodyweight on your shoulders... STOP EVERYTHING!!!!
Put down your iPhone
Put down your designer microfibre towel
Walk over to the squat racks and squat the bar many time.
Add 5kg each side. place bar on upper back and squat many times
Continue doing this until you need to lie down for a while.
then lie down
then get up
then do 4 more sets.
Pick up your iPhone, micro fibre towel, your bottles of pre and intra workout drinks, full up your post work out drink bottle and drink it.
get home and eat many many animals and stuff animals eat.
go back in 2 days time and do it again.
repeat for 3 months.
https://www.sau.com.au/forums/topic/422759-squats-the-challenge/
  • Replies 82
challenge for the ladies? I don't know many girls who can squat their own body weight for reps
Really? I thought you trained at Elite Physique in Canberra. I saw 15 do it there at the last comp, only a handful were PL'ers, most were Crossfitters or physique competitors, a few went 2 x bw
Canberra has some very strong girls
might give this ago.
dont expect i'll get many reps out compared to others here but hey we will see. Weighed in at 67kg so I'll attempt at 70kg cause i'm a big kent like that.
not sure how to upload the video either
Birds - stay up top to breath out and in, then down.... towards the end you might need to stay up top a little longer to take 3 or 4 breaths so do it if you want.
Do what you think is right instead of looking for ways to cheat.. lol
I'd say your hands/shoulders and lower back will be fried before your legs give up anyway so resting in standing position to wards the end will be hard anyway.
FIGJAM - upload vid to youtube
link it here.
Nah mate I train at Anytime Fitness haha, commercial gym in all its glory!
I'm more speaking for the girls on here.
  • 4 weeks later...
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
