MK Law
Phone: (03) 9596 9647
Fax: (03) 9596 9657
Mobile: 041 555 7011
Email: [email protected]
Registered Office: Level 8, 350 Collins Street Melbourne Vic 3000
For future ref ^^
Fantastic thanks, if anyone has any other recommendations let me know so I can pass them on, in case hes not happy with advice from the one above.. thankyou :)
lol @ u being the one to reply.. thanks Graeme!! Its for loss of licence.
He was on one point option then incurred another speeding fine and lost it for 6 months. But because it was excessive speed (40km/over) he has just lost it for another 6 months.. so will now lose his job.. (its my boss's son). From memory of our discussion the other day anyway..
He was done doing 100 through a roundabout near Rye.. apparently speed 'automatically' drops to 60 at a roundabout.. I personally did not know that?? I fly through them regularly.. like most other ppl I noticed..
Also I noticed in Cranny on the weekend that you can see the 100km sign on the other side, from the entry side of every roundabout.. so the whole thing seems stupid...
Anyway they need to try to do something so he doesnt lose it for another 6 months.. hence lawyer to talk about options..
Thanks for any help..
Hey Kaz,
Do you know which roundabout in Rye? Are you saying that it was an unsigned speed change?
I've just looked on the Vicroads site, and couldn't find anything about a speed limit automatically dropping for a roundabout on either the Speed Limits section or the Round Abouts section...
I know that most of Rye does have a 60kmh speed limit though...
He could be in a tricky situation considering his previous offenses...
Best of luck to him.
Must be one of those laws we are all just supposed to know about, like the 100's of other ones no-one is ever taught.
I have never heard of this, other than my dad mentioning it once years ago, that you should slow to 60 for any intersection. I just assumed he was crazy as that would cause more accidents.
Haven't heard of any law like that - however, surely discretionary powers allow a picky officer to get someone on reckless driving if they go through a roundabout too fast.
I looked into MK Law when I got nabbed speeding at 28 over the limit (down at mornington peninsula, when I was on my 12 months probation). Apparently he doesn't take minor cases.
Due to time constraints, I choose not to represent people who contest traffic infringement notices issued to them by police. I concentrate on matters where people have been charged and have either been bailed or summonsed to appear in court.
How'd he get caught? Does he need to appear in court or was he just issued a TIN?
i had to front court recently for a single speeding offence.
i spoke to MK law, however found him to be a little unprofessional, in my opinion not of the character i wanted to represent me in court.
MK quoted $1000 all up to deal with my case.
I ended up seeing Sean Hardy, had a meeting to discuss my case and i was confident in his ability.
SH cost me $1800 however the outcome of which i was very pleased with.
Yep. I went with SH as well and although he didn' represent me he gave me some good advice. recommended.
Sean hardy really well known. I have gone up against him before.
I also have never heard of this law. Stretch of road without sign in built up area iis default to 50 but otherwise is speed limit of last speed sign affixed until sign to change it.
Probably should have charged with speed/manner dangerous but took the lazy/easy option to give TIN, 2 min work compared to 2hrs
  • Like 1
  • 4 weeks later...
That's what I thought. When I went for my P's the instructor told me never to take a round about faster than 50km however the assessor in the back had said that there was no law actually saying that it legally had to be taken at 50 and to take it at a safe controllable speed close to the speed limit.
Have heard good things about Sean Hardy but no personal experience.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
