G'day all,
How does every else with >200rwkw cars go for traction?? I have a daily driver R33 gts-t with 210rwkw and find it very difficult to get traction on the street. In first and second if I put the foot down, I get wheel spin. I could do a quicker quarter with a stock car at the moment.
Current mods that could be causing this:
-Twin plate clutch
-Hankook Tyres (cheaper)
-Tein coilovers
-265/35-18 tyres
I have a few theories:
- obviously softer (read: more expensive) tyres would help
- softer rear suspension may help????
- Would a narrower tyre (255/40-18) help? ie. greater weight per square inch of rubber on the road
I'm assuming that I'm not the only one with this problem and want to sort it out before I upgrade the turbo. No good having 260kw if you can only use it on the dyno. As it's a daily driver I'm not looking at spending too much on the tyres. Hoping to keep it under $500 per tyre and with relatively ok life.
Cheers,
Bleck
https://www.sau.com.au/forums/topic/42279-traction-probs-with-rwd-cars/
  • Replies 46
I'd go for the rear suspension being too hard theory. I believe I have the same problem as I'm running Kei Office coilovers, and there is bugger all traction 1st, 2nd and sometimes 3rd. I'm looking at getting a set of softer springs made up for the rear though as many people have mentioned before that most Japanese coilovers spring rates are about twice what they really should be for the roads in Australia and New Zealand.
well mine doewsnt have anywhere near 210kw but i noticed that with the old tyres(bald) it was very silly trying to get traction on the street coz they just spuin everywhere, i was in the same boat 1st 2nd was just spinning, however i went and got osme new tyres and they were 245/40/17's bridgestone Grid II i have to say these are better than the 255 tyres that i had on it previously, much better traction, 1st only spins a little with 2nd on spinning on gear change then she al go fromthere. maybe try different tyres, i got tein adjustables on mine and i have put em lowish, i still ran 13.5 with my shitter dude so i reckon u should be able to do at least that. twin plate may be a back foot step, although nice and strong, i think the ability to slip them isnt as good as your average organic shit one like mine
try putting in more positive camber so that when the rear of the car squats under hard acceleration there is more tire contact on the road then now with the standard settings..
i am not sure what the camber setting are on a lowered 33 or standard height car but when they get lowered the rear camber will go higher into the negative setting then there should be..
even a 1/2 to 3/4 positive camber change will not effect tire wear..anything above 1 degree will ..
or just go to a solid rear end then all your problems will be solved.. hehe go the 31's
i had the exact same problem when i had my stockies on and i only got 172rwkw since i purchased my rims (19x8) with 265/30 tyres on rear thats stopped lol their freakin heavy bastards, but yer with stockies like mentioned 1st gear a waste and 2nd gear still spinnin.
cheers...ben.
Ive got 166rwkw and i spin my dunlop 255/40r17 fm901s like they were spacesavers
They are mega old tho,
Getting Falken RT215 255/40R17 SemiSlicks next so i cant wait to see what happens
-Ive got full whiteline handling kit, strut brace and tein suspension/springs
Ive got 0 neg camber on the rear, pineapples set for traction, and a set of brand new bilsteins with lowered pedders springs.
TRACTION ISSUES. I also/STILL get axle tramp
I might go decent 255/40 instead of 265/35, more sidewall more traction?
what decent semi comp tyres come in 18" that arent 600 a tyre
i have been driving a 205rwkw 33 for a long time and now a 223kw with no real traction problems USING HANCOOK TYRES.
they are shagged and i need new ones and i can still get the power to the ground.
i beleive the susp on my car is not stock and thats probably the difference.
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
