I have just got 2006 V36 350GT SP and I would like to know where I can actually get a proper sticker if they exist for the drivers door showing the tyre and rim size chart.
I can assume that this has been put on there as part of the compliance process and it was stuck there with cheep glue that is half fallen off now.
I have looked and can't find anyone who has these for sale. I can make my own as you can see in the attached it looks like that is what the person who did the compliance has done. Just looking for something more professional or neater then the flimsy piece of photocopy paper half stuck to the drivers door.
Or do I just rip it off and clean off the sticky goop and never talk of this again?
All new to this skyline business just want to do the right thing.
Thanks
I did a forum search and couldn't find anything relevant.
Edited by LegionMe
You will need this for registration purposes. The Japanese one does not count, as I discovered when I went to Vic Roads... Whilst you can remove it, once you have the number plates on your car, subsequant owners, if interstate, may still require it..
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
