Anyone got a part no Bendix Ultimates for the RB33 GTS25T
I'm sure it's on these forums or the SDU forums but I'm damned if I can find it . Also does anyone know anything about Platignum pads apparantly made here in Aust Thanks Jay
https://www.sau.com.au/forums/topic/4229-disk-pad-part-no/
Are you sure..
I thought only the R32 GTS-T Used the same brakes as the 300ZX Z32.
I think the fronts on the R33 are the same as the R32 GTS-T but the rears bendix don't make them.
I remember when Whatsisname had brakes fitted and i'm pretty sure he said that he couldn't get bendix brakes for the rear only EBC.
I Could be wrong but.. :)
I have bendix's PDF of brake listings on my www site..
EDIT:
No i don't i thought i did.. sorry :) I'll have a look but..
To make sure I actually Emailed Bendix and they replied very promptly when i did the brakes on my R32.
https://www.sau.com.au/forums/topic/4229-disk-pad-part-no/#findComment-67730
Originally posted by -Joel-
Are you sure..
Well I've just bought a set of the R32 front and rear ULT pads. The PN's I've given are the ones for the R32 GTR, and they are the only ones that Bendix list. But, if you look at the DBA catalogue, they say that R32 GTR, R32 GTSt/GTS4 and R33 GTSt use the same rear disc (DBA908) and I'd be very surprised if the cal wasn't also the same. I have a pair of the R32 GTSt rear cals with the factory pads in the garage and as far as I can see the Bendix pads are identical.
That said, it still could be they're different [shrug]....
https://www.sau.com.au/forums/topic/4229-disk-pad-part-no/#findComment-67735
Joel,
I run EBC Greenstuff on the front (P/N - DP21200). I run EBC Street Kevlar on the rear (can't remember the P/N).
EBC don't make a Green' for the rear.
These are excellent pads for street use. Even hard street use is unlikely to see brake temp's much over 450'c-500'c, EBC Greens are rated to 650'c.
Fronts - ~$200-$220
Rears - ~$70-90
Bendix Ultimates are rated to 550'c, so they're just as good for performance street use.
The R32 GT-R uses the same calipers (F&R) as the R33 GTS25t.
https://www.sau.com.au/forums/topic/4229-disk-pad-part-no/#findComment-67758
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
    • Oh, yes. If you connected it to the manifold your first drive would be very eventful. Very shit. Very interesting. Perhaps take a video if you feel the need to see. Terminating the breather at the top of the bellhousing is normal/stock. Some gearbox lubes (hello Redline Shockproof) like to foam up a bit and require the breather to be extended up higher, so you don't get spots of smurf jizz staining the floor under your car. Mine is thus right up behind the head. Make sure you fit a u-bend at the top so it points back downward so that dirt and schmutz has a harder time getting into it.
    • Cheers for the replies. So i don't connect it to the manifold I just run the hose high up on the firewall?
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
