M35 Humans,
Just wondering if anyone has come up with a definitive fix for the delay from the time the throttle is mashed in 1st gear to when you actually get full power?
Its always been a bugbear of mine with the M35s I've had and now I have one that I'm going to hang onto I want it to disappear.
I was thinking of a throttle controller of some description but I'm not 100% sure it will do what I want.
Many Thanks In Advance.
Jeff
Throttle controllers don't work, I have tried one. The throttle restriction is built into the ecu, and occurs when the brake signal pin is energised. It also latches for 3 seconds after the brake is released. You need to cut the brake signal wire to get 100% throttle, but this will eventually throw a CEL so you need to wire a switch across the wires also.
Do a search, there are a few threads on the throttle restriction and brake cut mod. Highly recommended.
Thanks for the tip guys. The car finally arrived today so once its complied the mods will begin. And yes its the car Marc would have been talking about. Still working out whether to RWD and 6 speed it or not...
I have 2 6 speed boxes here for the same reason, but I couldn't bring myself to ruin the car, keeping it awd is the only way. Why not drop a 33 GTR box in there? :)
that brake cut mod is awesome. you get CEL after about 8 days though if you install a switch and just touch the brake pedal CEL is cleared automatically. even just driving around town the car feels so much better.
Besides the cel coming on does it do anything else? I.e changing gearing retard timing ect?
Other than resetting the CEL every so often (there are ways to automatically circumvent this with some extra wiring), there is only good to be had from this mod.
If the cel comes on it cuts boost and fuel, so be aware if runnig and EBC or manual bleed valve.
Really? I found absolutely no difference on mine. However, I always reset the the CEL quite quickly. No idea what happens if left for 100's of km.
    • Don't turn down the limit yet. Put a mechanical pressure gauge on the car in the same spot and go and prove it.
    • I've done a few BMS systems. Code in Canada use to force us to have any safety components outside of the PLC but with a code change back in 2018 I believe it was, we can now use safety PLC's to control everything. Sadly to your point, AB Guardlogix safety instructions for example are only available in ladder.  Machine safety is a very big thing here though, you're constantly forced to migrate to the next best thing by OSHA. I honestly prefer safety plc's, including anything from AB more then I do working with old school safety monitoring relays. PLC is only one portion of it, the rest of the electrical still has to follow to meet SIL (Mechanically linked dual contacts, bla bla)  Now tell me how to feel about safety over comm's (e.g Ethernet/IP CIP) on a unmaintained network haha
    • To your point, boolean logic. We're not only working with bools in ecu's, so it's very limiting. I wanted to setup a low WMI pressure alarm. After 1 second I want WMI line to hit 100PSI, 2 seconds 175PSI, etc. and trigger an alarm if it doesn't meet those thresholds. This would of taken me one very short line of text, but instead I had to bugger around with generic timers, conditions, etc. and so forth.
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
