Flat changing - not taking your foot off the accelerator when changing gear. Gets mad seconds, thirds, fourths etc... hurts the drivetrain (and motor if no rev limiter)
Double clutching - releasing the clutch in neutral between gear changes. Takes ages to change gears, but will at least go into gear if having syncro issues or hard to shift boxes.
are there any other techniques we could use when drag racing. The flat changing sound good. :)
Double declutching eg from 4th to third........clutch in-into neutral-clutch out- bring revs up to match your current road speed- clutch in-into 3rd-clutch out mostly used when downchanging, Your clutch will live a long and happy life.
Flat changing- go pedal flat to the floor-hold it there while you change gear. Your clutch will die very young.
Flat changing in a syncro gearbox is not a good idea.
Maybe when you install a straight cut dog tooth box it will be good.
Double shuffling or double clutching is probulary best described on forums such as "Diesel Landcruiser Australia", "Mack Truck USA" and "HQ Holden heaven"
However, heel and toe down shifting is all good!
Thanks alot for the help ... yeah i'm familiar with the theory of heel & toe it's just a matter of attempting it. But yeah, thanks again for the info on double clutching & flat changing.
Once again, you can have a helical cut dog box or a straight cut synchro box. Meh...
I just want to know what granny shifting is!?
hehehe....fast and the furiNAWS.
I granny shift all the time...if I don't i look like the biggest dick during peak hour :D
heel and toe is not double clutching in itself. simplest heel toe has nothing to do with double clutching, just to aid in downshifting whilst braking (getting revs high enough for lower gear).
of course u can add double clutching to that, but in a syncroed gearbox there isnt all too much point
    • I believe Unimog is the only vehicle that has it (from the manufacturer). I haven't seen aftermarket permanently connected kits, but I haven't looked either.
    • Ha ha ha, can't overthink when exhausted... Oh how I wish I had that power! I can be absolutely dead set shot, and my brain will still go "we need a good 3 or 4 hours to just think about everything and anything before you may sleep... My biggest thing is making sure I give myself enough sleep. I don't operate on even 7 hours of sleep! I attempt to give my body 9.5hours sleep a night to be able to function. I don't sleep the whole 9.5, but I need to make sure I offer a big window. I also take a single supplement, which is to help with long term health, and fighting inflammation, and I notice it helps massively. Especially me sleeping, and just less "achey" in the body. Have also kicked sugar, and gluten. A majority of people with ADHD don't go well with gluten. It causes a really interesting natural opioid overdose in the brain, which causes bodily issues and sensory issues.
    • Yeah that's what I meant, permanently connected not manual
    • Yep. But typically that's just run a hose down to the tyre while stationary.   Oh and the Unimog will automatically air up and air down tyres from the onboard computer for you too.
    • There was a good video somewhere, maybe Kurzgesagt that linked physical activity to ADHD/Anxiety/Insomnia etc. Basically the body WILL spend energy doing something if you don't spend it doing anything physical. It isn't fun, but I personally have noticed I've never been overthinky, or unable to sleep if I'm physically exhausted from doing a lot. The musings around it seem to indicate that this is one of the reasons/mechanism that physical activity improves mental health/wellbeing etc, by more or less not using that 'extra' energy to overthink, be anxious, inflammation, etc. There's also the fact that every obnoxious exerciser ever says it's great and helps which is extremely annoying. Like people who say the same thing about travel being the best thing ever. I mean, they clearly are, but blah. I started doing a LITTLE myself (think 3x15min per week) and honestly did notice the benefits, aiming at life quality when older. Which is sooner than you think. Getting something into your routine that you can actually make a routine has helped me at least. This post brought to you by procrastination between sets.
