hi all,
ive reciently brought a 2002 stagea.
im looking to firstly get the fuel consumption down and secondly get the power up.
i thought there would be more grunt available from the 2.5 V6 and 16.3 liters per 100 in town seems too heavy.
(im getting 9.5 on the open rd) ;-)
ive just done the plugs and fuel filter and service - no change.
the mech put it on the dianogstic and says the o2 senson is due.
research shows the main reason will be the o2 sensor.
also possible fixes:
new temp sensor
high tyre pressures
98 octane (ive been thinking 91 would be cheaper)
id like you views on the above and any other tips
does it have 1,2 or 4 o2 sensors?
where to buy?
http://o2sensors.com.au/search/application?makeID=29&modelID=2575&engineID=3037 $200 each
http://www.amayama.com/search/?q=22690AL600 varyies on oem or copys..
are non nissan parts ok?
thanks for your input.
jim
https://www.sau.com.au/forums/topic/422947-vq25dd-tune-tips/
You won't get much of a response in this section, head into the Stagea forum and ask your questions there Jim.
Amayama would be the place for parts, genuine Nissan and cheap. I doubt replacing the o2 sensors will help much, these are big thirsty 2T wagons and you have the smallest engine available. Perhaps you can do a test on them before swapping to see if they are slow to react?
The first thing I would be doing is removing as much of the intake as possible and cleaning all the carbon out of it from the egr valve.(I hate these valves) You will see the swirl valves in the lower intake then, and you can decide if you want to remove them, or simply hold them open? They are there to help improve chamber swirl and lean running on the open road though. You rarely get power without losing economy on the factory ecu especially.
91 octane would cause detonation (pinking), the factory ecu would detect this and drop out timing causing a soggy feeling on acceleration. You have a very lean burning high compression engine so it needs all the help it can get, especially now it is building up inside with carbon deposits. I would be using 95 as a minimum.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
