Hi there
I have found some discussion that people replace their springs with 350z springs to get 1" of lowering. There seems to be a fair few variables about which years and types this works for, and whether to use revised or non-revised springs etc from the 350z.
For my year of 350gt can I simply replace the springs with 350z springs? Should these be revised or non-revised? Will I need to replace the shocks or install a camber kit?
Please excuse my ignorance as I have never lowered a car before and don't know anything about it .... just think that my car will look much better sitting a bit lower :-)
https://www.sau.com.au/forums/topic/422970-lowering-2007-350gt-type-s/
I am assuming you have a V36? If so, then you can't use 350Z springs I am pretty sure - they are the same as the V35 springs - not V36.
But, I am not sure if the 'swap springs trick' works the same with the 370Z or not - I assume it would.
Isit a sedan? If it is a sedan and its 2007 then yes it's a V36.
Why don't you go for after market springs? Like Eibach Pro Kit Lowered Springs? I think they have better spring rates and it drops about 1.1"
Hi yes it is a sedan. So I guess that settles that it is a V36. Despite previous poster's comment, its not self evident!
Thanks for your suggestion about the Eibach springs - so just the springs or would I need to replace the shocks / or add a camber kit?
I have the springs. It is a direct fit/drop into the stock shocks.
I did not get a camber kit. It would be awesome to put one it if you have the cash...I didn't think it was necessary for my use...
IMO, the ride quality was not compromised. You feel the road abit more and theres more stability as well.
I'd get a sway bar if I were you. Best purchase ever :P
Edited by colin.ssc
If you are only dropping around an inch then the general rule is you don't need a camber kit. You may see a TAD mote wear on the inner edges of your tyres, but that is about it.
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
