I've organised with Steve from JAZMAC performance centre Mt Barker to hold a dyno day there on Sat 26th of June. Start will be 10am with a BBQ lunch thru the day.
Steve has the newest dyno in SA at the moment and it is ours for 3 Power runs for $30.
People who remove their car from the dyno then want to return later to try again will be charged $10 even if u didnt get 3 runs on the first loading. (alot of cars find they are too lean too continue).
If u only want to check your mixture's or want to know the results of your latest mods then this day is perfect for it. (normally around $60).
Im after rough numbers for now thanks; Please post your interest on here.
https://www.sau.com.au/forums/topic/42299-dyno-day-june-26th/
  • Replies 93
I'd better check with the boss, but likely I'll be there. MattR and MattWhatsisname and others from the North-East area we should do a meet up (maybe at my place) and mini-cruise together.
hehe Chops, have you moved into your new place (a whole 100m from my house) yet? I take it as a no, cos we keep dropping around hoping to find u and the missus home and you never are (like 9:30pm tonight).
