  • Replies 93
I'd better check with the boss, but likely I'll be there. MattR and MattWhatsisname and others from the North-East area we should do a meet up (maybe at my place) and mini-cruise together.
what time are you guys going there? what time is the meeting?
I'll try to come with my mechanic (no not in my car :D ) if he's not working this weekend.
Dan, I was thinking maybe meeting at my place at about 11am or something - which will allow me to have my customary Saturday morning sleep-in, and will enable us to have a fashionably late entrance :) .... I'm open to suggestions though!
Great post Matt, to get a reaction out of me btw :) .... 9am on a Saturday muahahahahahahaha
sounds good Nightcrawler....yeah 9am is pushing it a tad cheeky Matt :)
can I have your address nightcrawler?
It would be good if you could come busky. It's been a while since I saw you guys :)
How are your exams going? When do they finish?
if you're gonna come wake me up at some ungodly hour, you'd better make sure you bring Maccas brekkie or a dozen egss, 1kg of bacon and a loaf of bread, for bacon & eggs on the barbie (like last time :D ) .... hey, why don't we do a brekkie at my place before the dyno day for interested people?!
Am I allowed to enter an XR8?
I have nothing to do with the organisation of this dyno day, and unfortunately won't be able to attend :D - but I don't see why you shouldn't be allowed to bring your bog stock standard BA XR8 :)
if you're gonna come wake me up at some ungodly hour, you'd better make sure you bring Maccas brekkie or a dozen egss, 1kg of bacon and a loaf of bread, for bacon & eggs on the barbie (like last time :) ) .... hey, why don't we do a brekkie at my place before the dyno day for interested people?!
I'm happy to cook the barbie, no-one died last time, so I must be ok at it.
BBQ brekkie at your place it is then.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
