UAS Huge Stocktake Sale & Open Day - Saturday June 26th 2004
  • Replies 57
Cef: Your a discount bitch :D
To answer your questions on Johns behalf, the discounts will be deducated off the current catalouge pricing on their website.
Remember, to get a discount on items not in stock, they must be paid for when you place your order on Saturday.
Not sure on price matching - this is a stock take sale with heavy discounts already being applied. I dont believe there will be any sort of price matching considering its already a sale.
Rest assured UAS will look after as best they can.
Hope this helps
Nick
cause the wiring loom is already in place for a type 1.
if the same loom works for the type 0 then SWOOOOOOOOOOOIT
It sure does mate :D
Richard
It sure does mate :cheers:
Richard
By popular demand we have an assistant coming for the day, although she may not know a whole bunch about the Skylines, she will be willing to sit and listen about yours.
Check it out. http://www.bombshells.com.au/index2.html
By popular demand we have an assistant coming for the day, although may not know a whole bunch about the Skylines, but  willing to sit and listen about yours.
hahaha until I checked the link I assumed you were talking about me manning an SAU table :cheers:
will they also b 4 sale???
:aroused:
John, i sent you a 2nd email asking about the light weight flywheels. You said in your reply that they would be significantly cheaper than $495.00 on Saturday but that they weren't 5kg like your site says.
I haven't received a reply as yet.
How much will they be?
How much do they weigh?
What are they made from?
Thanks in advance
Adrian
and people thought I was crazy for suggesting a campout the following nite???? I'll be there before the sun is even up !!
yeah, druncan will draw the crowds from far and wide!
Richard
Will there be male assistants (other than yourself ofcourse John). If not, my Amex is staying in my pocket.
i'll be there, and in case you have forgotten what i look like, heres a pic...
    • Ok awesome! I’m not running a aac/iacv (although I do have the r34 iacv but I’m running the heater core loop. I’m running the chase bays booster delete so In that case would I need to block off those posts? So at the moment I need to run from one of the posts to the fpr and then a separate post to the boost controller then to the wastegate? Also I’m assuming that each port has a specific use like the first one farthest to the left would be (for example) manifold to fpr and then second would be to boost controller?
    • I was just going through this on Neil's car (33 gtst). Assuming you are using standard AAC and Cold start valves, you need Post Turbo Pre throttle to Boost Controller (if you have one) then to Turbo Wastegate Pre throttle to AAC input AAC input T piece to Cold start input Cold start output to plenum post throttle AAC Output to plenum post throttle AAC Output to brake booster (needs a 1 way valve) Plenum post throttle to Fuel Pressure Regulator Plenum post throttle to Blow off valve signal Plenum post throttle to Boost controller input (if you have one)
    • I’m trying to figure out the purpose of these fittings. Assuming they’re for coolant but not sure where the lead to. I know the bigger one on the right (which isn’t filled) is the brake booster. If anyone has a photo of a diagram of this intake or has a set of instructions it’d be greatly appreciated
    • How much is that r32? Is that $170k or $1.7m
    • Ahhh! My silly brain was thinking Nissan started selling them straight away, but they waited w or three years didn't they?   Maybe Duncan should build an R35 race car over the V37... There's a cheap yellow one on car sales Duncan, would only need your splash of purple added...
