For sale is an incomplete project that needs a bit more work to get it on the road. It as a fully working rb30det conversion with rb25de head fully reconditioned with 100lb valve springs. It also has the following,
Fully recoed r32 gtr gearbox
Npc organic heavy duty clutch
New genuine front and rear main seals
Drilled out sump return holes
New CV boots all round
New 52mm rad
Nitto oil pump
Tomei 1.1 oil restrictors
Arp rod, mains and head studs ALL L-19!
SPOOL rods
CP pistons
New timing belt locator holes
New tensioner pulley
New idler pulley
Rebuild starter motor
60mm genuine tial wastegate
T04e t4 top mount turbo
Nismo engine mounts.
New Welsh plugs
New water pump
New JJR interior kit.
Side intake plenty with velocity stacks
New aac valve
New cold start control valve
R32 gtr injectors fully cleaned
Bosch FPR.
BOSCH 040 fuel pump.
New fuel lines
New front brake lines
Fresh rebuilt brake booster
New BM57 brake master cylinder
S14 stubby clutch reservoir
Braided clutch line
Apexi avcr
4wd kill switch
New genuine cam seals
Genuine rb26 head gasket
Mod plated for turbo kit, bigger engine and modified front reo bar
Clear front side indicators
Genuine steering wheel just put back on, needs to be recovered though.
New genuine coil pack loom
New yellow jacket coil packs
Fully balanced engine!
Sorry stuff is all over the shop just trying to remember some things.
Now SOME of the stuff I have receipts for. Due to the qld floods we have had I lost a lot of paper work
it also has nistune ecu which still needs to be tuned
It also needs the dump pipe and wastegate pipe finished plus a few other little things for rwc.
Will post up pics soon
Looking for $25000 ono
https://www.sau.com.au/forums/topic/423001-r32-gts4-4-door-rb30-awd/
You may want to consider parting out or revising your price if you are serious about selling this, as you are asking tidy gtr money for an incomplete gts4.
In all honesty I don't know how you would go getting this money for a complete car, but it's hard to say without any pics
Sounds really cool, but ^ he is right. Parting it out if you have the time would be the best way to get back some $$. For comparisons sake, there is an R32 with fresh respray, rb30det (300+kw), immac interior, complete ready to drive for $13k on these forums.
Best of luck though, sounds like you've put a lot of time, effort and $ into it so far....shame these cars aren't worth all that much any more....
Yeah true. But 4 door gts4 are becoming rare and so ask a good price. I talked to one import car sales guy in SEQ who's quite well known and he reckons in the right circumstances there's no reason I wouldn't get 30 k for it. I honestly thought the guy was on drugs and a couple of other import car sales people also told me 28 and 27! Due to the fact there is no redbook price for these apparently.
I would be happy with 2004 mkll xr8 manual or 2002 sti. I read the post and I can appreciate where you guys are coming from. But I guess my centimental attachment to it from all my hard work maybe blinding me from the truth of the price. Has taken 2 years of consisting working on it myself to get it there almost nothing has been out sourced other then machning and parts.
^^ call what you want. I have 24k. Thanks very much. The vehicle has been advertised elsewhere for a while and has had several parties interested in it. Maybe next time you should consider a big view of a picture bar what flickers of sight you see...
I just think you are full of shit. This may have been advertised elsewhere, and you may have taken picutres that I wanted to view but could not sight as they were unseen, but from what I read, the engine ran like crap last month, the parts list is not all that impressive, nobody was intersted in buying your engine, you don't provide a phone number in your sale threads so I doubt your seriousness and finally I have my doubts in anybody with any sense having purchased this home built beast for 24k. 7-8k, maybe, but not 24k.
Lol don't need to supply number unless its necessary from a pm and yeah it was running like crap thanks to a warped brand new manifold leaking air, but luckily for me the supplier gave me a brand new one that wasn't, runs like a charm. And secondly did I come to your threads bashing on yous? No so f**k of you rude dream boats jam your heads back up your arses and please keep talking shit elsewhere. The person who bought the car has seen EVERYTHING that has been done and knows the car was done miticuosly. Next time ill come picking on your threads and bashing. If your so f**king bored in life and you get your kicks out of giving shit to people you need a f**king drop kick in the head or your just a pathetic f**k with no life either way f**k off.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
