Can anyone give me an idea what clutches are out there that are strong enough to take 650hp but still be drivable around the street without lurching at the intersections. My gtr has a insane twin plate in it that the second u release the pedal the tiniest, the clutch fully engadges making town driving very uncomfortable. Ive been told the Nismo super coppermix clutch is meant to be really good (link below) but wondered if anyne has one an could tell me what its like, or any other suggestions of a clutch, I drive the car once a week if that. so having that insane twin set up, whatever it is, is too much.
Any help greatly appreciated :-)
http://www.nismo.co.jp/en/products/competition/clutch/sctwin.html
https://www.sau.com.au/forums/topic/423011-best-clutch-for-high-hp/
Its gotta be good to be Nismo :-) My car beig sent for new dyno after they've put a better fuel set up in the boot, an Im swapping ecu to hks fcon vpro, so gonna get the clutch done then, cant wait to see the results of it all
you can use a single plate clutch for over 1000hp applications, but wont be very streetable..
i talked to the gearbox engineer at rapisarda racing and he told me to go for a nice single plate clutch for my track car.
but any twin plate will be abit tougher to drive,but the nismo twin is easy as hell to drive even around town. was in a 260kw r33 with one in that and was heaps easy.
I used to have an Exedy twin and it was a pig in traffic and the pedal was a lot heavier than standard. I now use an ATS triple carbon clutch whick feels like a standard clutch to drive. They're also a lot lighter which makes it easier on gearbox synchros between gear changes! The only downside is that they're are fairly expensive, but if you can afford to run a 650hp RB then I guess you can afford one of these. Highly recommended!
http://www.nengun.com/ats/carbon-clutch
Edited by Never Enough
Thanks for the help guy :no:
Im happy to spend to money to get the best clutch for the job, what I want to be sure of is, it's not that the pedal is too hard to press, mine feels only a lil harder than factory, but the issue I have with the clutch is it fully engadges as soon as u release pedal the tiniest, so its great for launching, but not great at traffic lights, whih the car spends more time around town than a track, So with the ATS triple carbon clutch is it streetable in that sence, The Nismo clutch read up says its good for round town yet still tough enough to take the power.
The ATS clutch slips well but once it warms up it tends to grip harder so higher revs are required from a standstill start. If you search there's other members that have posted similar questions to yours. This should help you make your choice.
I run a single plate that will take 650hp and is daily driven, very nice clutch.... A bit bitey on occasion but much better than a lot of aftermarket clutches...
single plate clutches because of the very nature that its just one plate..need harder springs to hold the power thus its heavier. Twin plates and so on increase the friction area by having multiple plates which engage progressively thus the springs can be lighter. however, once they engage, they engage. there is hardly any biting point.
Have only used ORC before so I cant comment on other brands...but I love the ORC twin plate :)
  • 4 weeks later...
I've got a nismo coppermix twin comp edition in my 32 GTR and its superb! It did take a while to bed in as the competition one is a bit sticky but after some driving and a few launches its smooth as silk. It gives plenty of pedal travel and is easy to drive. I forget its even aftermarket... It's almost stock feeling.
Expect around $1800 for this one
Nismo C Spec coppermix. Been in my car for 7 years and never slipped. Drives awsome.
Coppermix twin spec C, love it, smooth takeoffs and very easy to use :D
I agree 100% with these two, drives like factory and holds well over 400 in stroker engines
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
