Hi all
Have just converted my car to E85 and have began tuning it. It is great but does use a bit more fuel.
due to the lack of e85 at servos at the moment i am going to install a fuel cell in the boot as a sub tank so i dont have to carry jerry cans around on long drives and cruises. This is how i am going to hook it all up.
-Obviously the fuel cell in the boot
-Carter (lift) pump being gravity fed from base of the tank, pump will have a switch in the dash and when on will deliver fuel to the main tank, -The car already has a surge tank external pump setup and this will pretty much stay the same.
-Fuel sub tank will be spliced into the Return line from the surge to main tank and will have a check valve on both,
I just want a second opinion on the way the sub tank feeds the main (will only be done when the motor is off.)
I have drawn up a diagram of how i will set it up
i know it will take a while to transfer but i want to use existing lines and they are all 3/8 so i will just have to deal with it
if anyone has done this another way it would be good to see how
Cheers.
Edited by PaulosECR33
https://www.sau.com.au/forums/topic/423022-second-fuel-tank/
Put the extra fuel cell on top of the tank and you just need a line to gravity feed it into the main tank when it is empty enough - a mechanical tap would do or a solenoid if you want to do it on the run.
Flex fuel, end of story.
Your plan for filling will work but its a hassle having tanks in the boot and extra pumps etc.
Also make sure the lift pump you buy is alcohol friendly. They don't like sitting with E85 in them for long periods
As piggaz and risking said. Flex fuel all the way. Ugly tank pumps lines ect taking all that room up in the boot. Just a major hassle. Get a flex fuel tune with the flex sensor and all that and you'll never look back mate.
    • I’m guess it’ll end up with a turbo
    • To install new hicas ball joints do i really need to pay for the Frenchys hicas install tool? Or can i use something like this? https://www.ebay.co.uk/itm/395524214497?_trkparms=amclksrc%3DITM%26aid%3D1110018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26asc%3D281023%2C280568%2C280618%26meid%3D4018390c9ba246f794ed58b8b19ec80a%26pid%3D101430%26rk%3D4%26rkt%3D12%26sd%3D205160403603%26itm%3D395524214497%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DCompVIDesktopATF2V2AndXaiHotClickWithCompV6WithEbertNRTRecall%26brand%3DUnbranded&_trksid=p2332490.c101430.m2460&itmprp=cksum%3A3955242144974018390c9ba246f794ed58b8b19ec80a|enc%3AAQAKAAABMDJfxvEKz%2FWsdyy97PIVwAhtkTIJPGKp%2Bu7TYjjsvNO4eN9duTRR%2FSVFYts6UXmN8tSK75ee0LypjLaKkPNQ2gkat4DyNLnViXKBVpI1%2B5fAYfWiGJa5QlqEPseqbSJUD9gVo2KSXbnmQjuPDJH4flTH2bOLSO%2FvMrLjgPDIc7vGrlKtoSauZb0q%2Fu43zLR0J8tg1z5dPMV%2FcHtnqRYXb7R7V8G%2FrQGhpY1sWtGJXc4TWc78ccs69UXnMiCqqd05ITd%2BY7Vwbq5Uzd%2FWhmiZCytO66vqDnbJn03qN%2Bin0ImF5sgbgu9uD45tXNN8cr4IWfqzIEEpaKcgqilwbTDxMkIQ4sGcgz7IhYONV017vE6P9ksZ7n%2FFVwgs3kAfMb0%2FLGjwaqhwo0yilTIjGHg9mwU%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01JMR0X9WMB8DPEX82P2P3CRXN
    • I would be lying if I said I wasn't interested in what MCM were going to do with the NC I really enjoy their banter and occasional collaborations (like Alan from TSF, Ben from BCW, or any of the Haltech guys throwing around their experience), and I have probably watched everything they have put out
    • Not yet, we basically drove it to a private road, got the logs and drove it straight back. I think I need a new passenger seat belt after the mrs squeezed the life out of it.
    • Sounds insane! 🤤🤤🤤  Do you have any vids of it driving?  A flyby would be nice!
